93 850 GLT CAT and O2
Old Mar 12, 2004 | 04:25 PM
tassadar30's Avatar
Default 93 850 GLT CAT and O2
Okay after failing smog horribly, I have to decide wether or not I should take it in to Volvo for a diagnostic. They want 130-150.00. The ecu is'nt showing any faults and wether or not Volvo finds the problem I get nailed for 150 bucks. I don't mind doing the work, but I need to be sure that either my O2 is bad or the cat is bad. Any ideas?
Old Mar 17, 2004 | 01:39 AM
GMech's Avatar
I drive a 94 Turbo but the diagnostic socket placement is the same as the 93s. I think you can use socket A2 to check the codes. (A6 is for ignition for the Fenix sys.) and then verify if they're repeating. <IMG src=smileys/smiley5.gif border="0"></P>
Have you also check all the vacuum connections and possibly a plugged flame-trap?? it would be likely to say the O2s are faulty if they haven't been changed since new.... but the cat? i doubt it.</P>
when i bought my 94 wagon used i had to replace both O2s to past the emission but ended up only the downstream one is at fault. and one vacuum fitting was borken on mine... so hopefully u can locate the problem indeed <IMG src=smileys/smiley1.gif border="0"></P>
GMech</P>
stevenro64
Apr 19, 2011 05:23 PM
adarren
Sep 30, 2010 04:37 AM
bjornagain
Apr 5, 2009 08:27 PM
Bruce Wayne
Mar 10, 2009 10:20 PM
Platinum52
Apr 17, 2008 06:10 AM
