Squeaking suspension
Old Sep 11, 2005 | 06:38 PM
900 Aero's Avatar
Default Squeaking suspension
Evening all,
I'm driving a V40 for a while and have to do a long trip up to Scotland in a few days. I've noticed there's an intermittent squeak coming from the front left suspension which I'm not sure if I should be concerned about. It sounds exactly like if you jump up and down on a bed. Doesn't happen all the time, and will disappear for some days, but always comes back. If I bounce the front of the car on that side I can recreate it. There's no play in the wheel, but the noise seems to happen more if it is pointing left. Is there a common cause for this on these cars? I wondered if it might be suspension bushes that have worn a bit, or if it could be something more serious. Car is a 2000 V40 2.0 manual.
Old Sep 11, 2005 | 08:29 PM
Default RE: Squeaking suspension
Could be a bad sway bar link or a bad upper spring seat.
Old Sep 13, 2005 | 06:57 PM
900 Aero's Avatar
From what I could see, the spring appears to be seated properly, but what would be the best way to test the sway bar? I'd rather not dismantle it unless I have to.
Old Sep 13, 2005 | 09:39 PM
You can tug on the sway bar and see if you feel it clicking.If you do it is bad.
marley
Dec 7, 2007 09:22 AM
JCVolvoS80
Apr 22, 2006 02:27 PM
ludeless
Mar 14, 2006 11:27 PM
Steamroll9
Feb 16, 2006 11:55 AM
rp850
Jul 27, 2005 12:45 AM
