’97 850 T5 A\C dose not work
Old Jun 28, 2003 | 06:41 PM
uj034's Avatar
Default ’97 850 T5 A\C dose not work
I have a '97 850 T5. A\C dose not work. When I start the engine A\C switch light blink 37 times,(for 45 seconds).Can anybody help me?
Old Sep 23, 2003 | 03:18 PM
CJean's Avatar
Seems like there might be a problem with the electronic climate control unit. I had a similar problem with my 93 850. I had it checked out, and was told that one of the sensors of the electronic climate control unit had failed. Obviously, i had to replace it, but at a $274 cost (Ouch!). BY the way, the repeated blinking of the "REC" and "AC" lights lets you know that there is a problem. In some cases, if I tried to turn on the heat or ac while they were blinking, the fans would not even work! It seems like it might be a malfunctioning sensor. Good Luck. </P>
Carl</P>
Old Nov 10, 2003 | 06:46 PM
rodsob's Avatar
does the A/C compressor cycle on or off frequently while idling? if so, then all it is low freon. easy to check and easy to replace. worry about the leak later, at least you know now it is just low in freon.</P>
if there is freon then i would check (with a voltmeter) to see if current is being sent to control switch when you turn on the A/C.</P>
do the easiest and most likely thing first and check the freon level. this is done by getting an A/C guage at your local PepBoys. $10</P>
let me know how it works. </P>
danni
Sep 17, 2013 11:56 AM
SwedishSwagg
Feb 23, 2011 03:12 AM
kvangenechten
Jan 18, 2011 06:32 AM
waxk
Feb 9, 2004 11:46 PM
rhythmkitchen
Oct 7, 2003 02:43 AM
