97 Volvo 850 GLT, A/C good, but noisy
Old Jun 18, 2009 | 04:08 PM
stojakovic's Avatar
Smile 97 Volvo 850 GLT, A/C good, but noisy
Whenever A/C is on, there are noises around compressor. No noise at all when A/C is off.
A/C is cold and never stops.
A serpentine belt or idler pulley problem? The timing belt was changed this Feb.
After search on this forum, I think I already get the answer, right?
Old Jun 18, 2009 | 04:15 PM
850tony's Avatar
depends what kinda noise it and and stuff. but sounds as though it could be a bearing or the clutch.
Old Jun 18, 2009 | 04:25 PM
stojakovic's Avatar
Right, may be just before the A/C stop working......
Old Jun 18, 2009 | 04:36 PM
850tony's Avatar
a/c usually stops because there becomes a leak in the lines that lets the freeon (spelling?) out.
Old Jun 18, 2009 | 04:59 PM
stojakovic's Avatar
My assumption is that it is not a serpentine belt... as when A/C is off, no noise at all.
Old Jun 18, 2009 | 05:25 PM
850tony's Avatar
ya but when the a/c is off then the a/c compressor disengages (because of the clutch on the compressor. so it "could" be the belt.
is this noise a squeal, or metal on metal rotation sound, or a clank or what is it?
Old Jun 18, 2009 | 08:55 PM
I would say the compressor has been low on oil in the system and the compressor it going bad.
Old Jun 19, 2009 | 09:59 AM
stojakovic's Avatar
I have no idea to describe the sound by these terms. I uploaded a video on youtube, so you can check and tell me which it is.
http://www.youtube.com/watch?v=eee3-7EhcXA
Here are what I have done: start engine, turn on A/C at 00:00:34, turn off it at 00:00:46, turn it on again at 00:00:50, turn it off at 00:01:04, race the engine at 01:00:07. You can hear the noise caused by turning on A/C.
Old Jun 19, 2009 | 06:51 PM
stojakovic's Avatar
Is that metal on metal rotation sound?
Old Jun 19, 2009 | 07:31 PM
The compressor is bad. Sounds like it did not have enough out and went bad.
Old Jun 19, 2009 | 09:54 PM
stojakovic's Avatar
Well, it still blow out pretty cold air. I am in Dallas and feel good with that.
Old Jun 19, 2009 | 10:02 PM
Yes but one day it will stop.
Old Jun 21, 2009 | 03:33 PM
stojakovic's Avatar
Just purchased one used compressor for $40 on ebay in case. I am not sure what other parts I should also prepare, but drier, o-rings.
Old Jun 21, 2009 | 06:30 PM
bestharry's Avatar
add a can of compressor oil and let it go untill it gives up- that might still be few years from now.
Old Jun 21, 2009 | 07:25 PM
stojakovic's Avatar
Any easy way to add it?
I found it not easy as i thought.
http://www.ehow.com/how_4762765_add-oil-ac-compressor.html
Old Jun 22, 2009 | 08:50 AM
bestharry's Avatar
Thats a much longer route. What I do is get a can of 'Redtek' oilcharge from partsource and connect it to the adapter kit and connect the kit to lowpressure side port. Start the car with airconditioning on and just empty the can into the system following simple instructions.
Cost= Less then $15 and total time is less then 10 minutes.
Following links might give you some information and wath the video in first link:
http://www.redtek.com/products_refr.html#
http://www.redtek.com/win_oilcharge_prod.html
Old Jun 22, 2009 | 08:53 AM
850tony's Avatar
nice!
Old Jun 22, 2009 | 01:40 PM
stojakovic's Avatar
I have been to Autozone this morning, and they have PAG recharge kit.
For Volvo 850, which viscosity is best? I think 100 is OK.
Old Jun 22, 2009 | 02:22 PM
bestharry's Avatar
Honestly, I never bothered about the viscosity figure and just always get 'OILCHARGE' can as in the link above and it works without any issues.
Old Jul 1, 2009 | 04:56 PM
stojakovic's Avatar
I add on can (8oz) compressor oil in and the noise seems decrease a little bit. Still feel trembling compressor when it is on, especially when accelerating.
Anyway, blowing cold air is good enough now.
