Timing belt change
Old Jul 21, 2009 | 02:44 PM
sandog's Avatar
Default Timing belt change
I'm in the process of changing the TB on my 05 XC90 T6 but could not remove the front TB cover. The coolant overflow tank has a hose that goes through the cover. How do you disconnect the plastic fitting. Do you cut the hose and splice it later?
Thanks!
Old Jul 21, 2009 | 03:45 PM
fcpgroton's Avatar
Former Sponsor
To my knowledge you shouldn't need to cut any hoses.
Old Jul 21, 2009 | 07:32 PM
There is 2 release buttons that are a pain to get pushed in. Usually the plastic nipple it is attached usually breaks and you need to buy a new thermostat housing.
Old Jul 27, 2009 | 11:45 AM
sandog's Avatar
Thanks got it off! I had to unbolt the black housing in front of the TB cover. It has two metal boxes that look like "hard drives". I did not remove those. I was able to move the cover out further to clear the plastic nipple. Now, I have another problem. I lined up the two marks on tha cam sprocket but unsure about the crank pulley and engine. In the attached photo, are the two indicators where the arrows are pointing the timing marks? This is my last step before removing the belt. I'd appreciate your help...
Thanks again
Old Jul 27, 2009 | 08:16 PM
Those 2 arrows have to be lined up. The top marks might be a hair off make sure the crank ones are lined up.
Old Jul 27, 2009 | 08:36 PM
sandog's Avatar
Thanks. I'll let you know what happens
Old Aug 2, 2009 | 01:32 AM
matt14's Avatar
How was the success on replacing your t-belt. Did you repalce your tensioner and idler pulleys? And how in the world did you get the hose off wihtout breaking the t-stat housing?
Old Aug 10, 2009 | 03:04 PM
sandog's Avatar
Default Finish at last
I've already driven over 2k miles on the new TB w/o any problems. Great success! Yes, I did replace the tensioner and idler puley so with the accessories belt (might as well).
I cut the band off the hose on the t-fitting, pulled off the hose gently, there are two serrated tabs, slide forward and you should be able to pull the fitting off. Just in front of the cover there is a box where the PS reservoir sits. remove the box, it comes apart half way and held by clips. Lift it upper half while holding the hard drives down (or ecm?). Remove the fan and piping as well. There're slip-on. After that, you should have enough room to pull the cover forward, clear the fitting and pull the cover up and out. It takes a lot of patience on first time. I have pics if you want. Tell me where to send! I spent $155 for parts. Labor...priceless!
Enjoy!
Old Aug 12, 2009 | 11:45 PM
matt14's Avatar
I've tried many times to save the t-stat housing and im unsuccesful every time. The tabs are to be pushed forward?
Old Aug 13, 2009 | 10:38 AM
sandog's Avatar
I know it's hard. I almost gave up especially in the small space you have to work with. I've spoke to several people (even the techs at JustAnswer.com) and they've said the same thing. I guess I was just been lucky. Yes, you have to slide those two serrated tabs in. It's probably stuck! Regardless of these circumstances, patience is what you need. Believe me, I almost was tempted to break it. Everytime I ran out of patience I walked away and returned after a while or did something else. Good Luck!
Old Aug 13, 2009 | 10:46 PM
matt14's Avatar
I dont have much paitence, but will try that method for sure next time. Maybe even tommorow, a co-worker is doing a head gasket on a T6, so ill try it then
Old Aug 14, 2009 | 02:42 PM
sandog's Avatar
I wish there was another way of taking those things off! Good luck...
Old Apr 6, 2011 | 12:28 PM
bulldog80's Avatar
I was so pleased with myself for getting the elbow off without breaking the nipple. And then....................broke the damn thing putting the TB cover in.
To heck with buying a new T-stat housing though. I just drilled and tapped it for brass fittings. Works great and won't break
Psaboic
Jan 10, 2007 03:06 AM
Psaboic
Oct 29, 2006 10:28 AM
postdoc99
Oct 11, 2006 01:12 AM
thejman
Jun 9, 2006 09:45 PM
Psaboic
May 9, 2006 10:36 PM
