will these rims fit ?
Old Aug 7, 2009 | 10:19 AM
malushi3's Avatar
Cool will these rims fit ?
i want to get these voxx mg rims and i have a couple of questions. im not sure to get 16" or 17". will these fit my car (s70 t5) and can i use the stock tires it came with if i get 16"?
Old Aug 7, 2009 | 10:20 AM
malushi3's Avatar
Old Aug 7, 2009 | 03:11 PM
jks2's Avatar
17" will fit in the wheel wells. As long as the offset is somewhere in the 38 -43 mm range you should be OK. We put 16" Mimas on my sons 850 and they look plenty big. Unless you just want to go larger, which will also make the ride a little rougher, then I would just stay with the 16's. By the way, good looking wheel which would probably look very good on your S70
Old Aug 7, 2009 | 03:29 PM
malushi3's Avatar
thanks
Old Aug 7, 2009 | 04:08 PM
Yes they will fit.
And if your s70 is running 16 inchers stock then the stock tires should fit these 16 inch rims.
Morader
Aug 28, 2011 01:18 AM
Delirious
Jun 30, 2011 12:54 PM
IsuzuFire
Jul 7, 2010 12:31 AM
VULVANATOR
Apr 21, 2010 07:47 AM
mistachins
May 10, 2008 04:01 PM
