Leaking anti-freeze
Old Aug 17, 2009 | 12:50 PM
tr_car_nut's Avatar
Default Leaking anti-freeze
I have been topping off the overflow tank on my S40 for the last two months but unable to find any leaks. This past week the car sat in the garage for one week and was not run and I noticed a small puddle under the engine on the passenger side. Further examination revealed anti-freeze coming from a small hose under the thermostat area. Is this difficult to replace this small rubber hose? And can I do it without removing other parts?
Old Aug 17, 2009 | 06:52 PM
It is a pain might be easier if you remove the power steering pump first.
Old Aug 18, 2009 | 11:22 AM
tr_car_nut's Avatar
I agree. It does appear to free up some room. I had the local Volvo dealer faxed me a cooling system diagram and the part number is 9463073 (tough to see).
Old Aug 18, 2009 | 07:22 PM
I have only ever messed with them when removing the intakes.
Old Aug 26, 2009 | 12:11 PM
tr_car_nut's Avatar
This past weekend I removed the power steering pump and was able to access that small cooling hose. It turns out the fitting that the hose connected to in the thermostat housing was loose. The hose was fine but I changed it anyway just to be safe. The toughest part was putting the serpentine belt back on.
Old Aug 26, 2009 | 07:15 PM
Glad it is good.
Ashokan1
Oct 11, 2013 02:56 PM
97850glt
Oct 11, 2013 02:51 PM
New Daddy
Dec 30, 2009 12:56 PM
04XC90T6AWD
Sep 23, 2009 07:41 AM
colgate41
Apr 23, 2006 09:54 PM
