ac compressor pulley
Old Sep 20, 2009 | 01:02 AM
matt2.3's Avatar
Default ac compressor pulley
alright so the volvo has been making this annoying squeaking noise when its running. so tonight, (saturday = car night) i popped the hood and decided to investigate whats causing the problem.
it turns out it has something to do with the ac compressor. the noise stops when the compressor is on and running. when the clutch engages (comp. off) it starts making the noise.
anyone know what that is? is it bad bearings?
Old Sep 20, 2009 | 08:13 AM
I would say the bearing in the pulley is bad.
Old Sep 20, 2009 | 02:50 PM
matt2.3's Avatar
yeah thats what i figured.
do you know how to fix that?
do i just need to pop new bearings in it or does it just need a whole new pulley assembly?
Old Sep 20, 2009 | 07:28 PM
You will have to replace the pulley. If you do it right with the right tools you will not need to remove the compressor. Nor will you have to drain the freon.
sasjzl
Jun 8, 2013 12:44 PM
docweedon
Jul 18, 2012 08:35 AM
haw09003
Jan 13, 2012 10:19 PM
guest01
Nov 5, 2011 10:11 PM
Walkie
May 2, 2005 08:53 PM
