alternator belt tension adjuster hitting water pump pulley / fan pulley
Old May 21, 2011 | 03:00 PM
guest01's Avatar
Default alternator belt tension adjuster hitting water pump pulley / fan pulley
I've never had this happen. I checked the the pulley was on flush. could it just need new bushings???
Old May 23, 2011 | 11:03 AM
bubba240's Avatar
Yes the bushings - the two under the alternator but also the one on the engine that the tensioner arm attaches to.
Old May 24, 2011 | 08:11 AM
guest01's Avatar
I replaced all 3 bushings and it didn't help, I had to wedge something between the pulley and the bracket while tightning the bottom (long) bolt.
This is so odd to me, now other car (that I know of) has this issue.
Old Nov 5, 2011 | 10:11 PM
dharrison49's Avatar
Default One more.
I have got an 86 240 GL. The tensioner arm looks like it might have a slight bend in it. It also seems to be somewhat loose on the bushing. Any idea where to get new or replacement tensioning blocks and bolts?
spaceycayce
Jul 28, 2013 05:21 PM
willyb
Aug 26, 2012 03:50 PM
brennanpersonal
Jan 2, 2009 09:17 AM
turbo940
Mar 31, 2008 04:35 PM
