Non-EGR intake on EGR engine?
Old Sep 28, 2009 | 09:01 PM
VTBricked's Avatar
Default Non-EGR intake -> EGR motor - Please help w/ vacuum lines!
I swapped a motor into a '95 850 and realized the motor I put in has no EGR. But the original motor did. So I went to swap intake manifold, but found the intake runners are significantly different sized with a different gasket, too, obviously.
My question is: Can I put the non-EGR intake back on the non-EGR motor and run the car with the EGR disabled/disconnected (but plugged at the exhaust manifold)?
Old Sep 28, 2009 | 09:12 PM
Turbo or Non?
Old Sep 28, 2009 | 09:14 PM
VTBricked's Avatar
Non-turbo
Old Sep 28, 2009 | 09:16 PM
Not sure if it will work on a N/A car or not. But on the turbo cars you can get a 96 ECU for no air pump or EGR and drop it in and go.
Old Sep 28, 2009 | 09:19 PM
VTBricked's Avatar
Hmmmm....this is not looking good....
Old Sep 28, 2009 | 09:20 PM
You can try it and see what happens. I will bet you can find the ECU cheap.
Old Sep 28, 2009 | 09:24 PM
VTBricked's Avatar
This just might work after all. Thanks Tech. I'll keep the thread updated.
Old Sep 28, 2009 | 09:34 PM
Thank you I hope it works out good.
Old Oct 25, 2009 | 04:28 PM
VTBricked's Avatar
So, now I have some extra hoses with the non-EGR engine installed. Although I'm not surprised, I thought I could easily find a vacuum line diagram to resolve my issues. And I don't have another 850 to look at....
I drilled & tapped to mount the EGR to the intake manifold - looks good.
1) So, the two lines off the bottom of the throttle housing - where do they go?
2) The large (3/8 diameter maybe) plastic hose with rubber elbow goes where? It comes from the battery side of the car near the bottom of the radiator.
I know there are two lines off the bottom of the intake manifold, but I only have one line (hooked up to proper line) on the non-EGR manifold.
So, I'm looking for one or more of the following:
- Vacuum line diagram for both EGR and non-EGR models
- Photo of EGR lines off throttle plate and intake manifold
- Descriptions of where they go
Old Oct 26, 2009 | 04:57 PM
VTBricked's Avatar
Bump.....
Old Oct 26, 2009 | 09:30 PM
Can you take pics and post them?
Old Oct 26, 2009 | 09:32 PM
850tony's Avatar
2) that is for your brake booster vacuum (hence the large diameter). i think it goes onto part of the elbowof the intake. i can check a little later tonight and let you know
Old Oct 28, 2009 | 04:55 PM
VTBricked's Avatar
Yes, I think I'll have time later tonight.
Old Dec 30, 2009 | 07:37 PM
VTBricked's Avatar
Default Update - it runs!
I put the non-EGR manifold back on with the EGR port drilled & tapped to accept the EGR line. I plugged the 2 vacuum lines at the throttle body. I put new plugs & battery in, turned the key. As soon as I had fuel, it started & idled! Yahoo! I need to replace the power steering pump and brake pads/rotors, then it will be good to go!
Old Dec 30, 2009 | 09:11 PM
Glad it is running now!
mourassa
Nov 19, 2011 09:22 AM
91shelby
Apr 29, 2011 01:04 PM
Erich73
May 19, 2009 11:40 PM
burnferris
Feb 8, 2009 04:43 PM
