Keyless Entry Failed SOLVED!
Old Oct 10, 2009 | 03:29 AM
darkdelta's Avatar
Default Keyless Entry Failed SOLVED!
1997 960 Wagon
A couple of years ago, I lost use of my keyless entry. Both remotes did nothing, changed batteries, checked fuses all good. Everything worked except the remote.
Maybe I am inventing the wheel again but, I came across this tidbit, and it worked. Apparently you have to reprogram the receiver module. This is done by:
1.Turning the key to position I or II five (5) times in ten (10) seconds.
2. Then leaving the ignition on (not started) Press either LOCK or UNLOCK on the REMOTE within thirty (30) seconds.
3. Turn ignition off.
It worked for me, I was truly amazed!!!
I hope this helps.
Old Oct 29, 2009 | 08:38 PM
960 rookie's Avatar
I gave up on mine. When I bought my car used, it did not come with a remote. After trying a couple purchased on eBay, all I could get them to do was lock the car- not unlock it. And I did the reprogram thing several times....
Old Dec 4, 2009 | 08:12 PM
SaintCam's Avatar
That's the trouble I'm having with my remote entry, on my '95 850SE Wagon.
My remote has only 1 button - when you exit the car and press the button, the car locks and the immobilizer engages. However, when you press the button again, the immobilizer dis-engages; but the car does not unlock.
Lock/unlock with the key works fine. So weird.
I'm wondering if the remote that came with my car is actually an aftermarket copy, and not the genuine unit.
EDIT: In an answer to my own question - no, that remote is not a genuine Volvo unit. So I've no reason to trust that it's working correctly... Time to track down some REAL Volvo ones!
Old Dec 14, 2009 | 02:00 PM
jlgood50's Avatar
From: Ringgold, Ga. Formerly Resided In Addison, Michigan.
I just bought a used remote on Ebay for my 960. I tried to program it like you described as did the owners manual. I cannot get it to work. I'm not sure if the batteries are good, so I contacted the seller to see what he wants to do.
Old Dec 28, 2009 | 11:59 AM
jlgood50's Avatar
I took the used remote I got off EBay to the Volvo dealer. It worked fine on their tester. My check engine light is on and that may be the problem in the system that is keeping the remote for getting programmed.
Old Dec 29, 2009 | 10:22 AM
Goat's Avatar
Glad you got it working. Now.... why is your Check Engine light on?
- Goat
Old Dec 30, 2009 | 11:48 AM
jlgood50's Avatar
One day I started to drive the car with the key not fully in the "on" position. I noticed that the tach & speedometer were not registering. I barely wiggled the key in the ignition and then everything was OK. The check engine light came on and to this day, I can't get the check engine liht off.
Jim
Cubic_Curiosity
May 12, 2015 07:11 AM
rickg
May 8, 2007 10:10 AM
JC
Nov 6, 2005 09:27 PM
dmoney
Jul 21, 2005 10:22 PM
rgarrett
Jun 16, 2005 03:08 PM
