Steering wheel shimmering
Old Oct 18, 2009 | 07:23 PM
dman777's Avatar
Default Steering wheel shimmering
On my Volvo 240 DL 1990, my steering wheel seems to shake on and off when driving. it does it for sure at 80 mph really bad. but 60 and below it does it on and off randomly with no logic to it. my tires are in really good shape(tread is very thick). however, in the two years i have owned my car i have not rotated them or had them balanced. could this be why? or does this sound like a steering/front end problem? just to add also, i had brand new tire rods put on about 8 months ago.
Old Oct 18, 2009 | 09:11 PM
Beardog's Avatar
did you do an alignment when you had the tie rods added on?
Old Oct 18, 2009 | 09:23 PM
dman777's Avatar
ya, they shop said they did(about 8 months ago). the wobbling in the steering wheel didn't really get bad until a few days ago(that I noticed anyways).
Old Oct 19, 2009 | 12:41 AM
tedv's Avatar
Tire balance most likely-a weight might have fallen off.
Old Oct 19, 2009 | 08:34 AM
Johnny Mullet's Avatar
I would start with a rotate and balance.
Old Oct 21, 2009 | 12:18 PM
dman777's Avatar
I went to the tire shop and one of my tires were almost bald and the rims were bent on all 4. they said they nicer the tire the smoother the ride would be. i ordered some peroni's tires 15" with aluminum rims for $800.00. My goal is to make my 1990 240 Volvo DL ride as smooth as possible. Was this overkill? Or will this give me a significant smoother ride?
Old Oct 21, 2009 | 08:08 PM
I suspect the ride should be perfect after all that especially if your rims were bent and tires were bald. Overkill? It all depends on how you feel about it. Post some pics of the wheels when it's done.
$800.00 for rims and tires sounds pretty fair. Hell, just tires for my mud truck are $200.00 each.
Old Oct 23, 2009 | 08:37 AM
dman777's Avatar
I read where a 14" inch tire has more side wall so the ride would be softer than a 15" tire which has less side qall. However, a tire shop told me that alloy rim makes a ride softer also. with a high quality tire like the yokohoma avid touring s, which would be more softer of a ride: 1) 14" steel wheel or 2) 15" alloy wheel? i don't care about handling or anything else...just want the ride to be soft as possible.
shanewilsonjr
Aug 1, 2015 04:07 AM
trainlover
Mar 16, 2014 08:48 AM
nehopsa
Jun 24, 2008 11:20 AM
tech
Nov 28, 2004 12:03 PM
jersey girl
Sep 24, 2004 12:37 AM
