brake pedal sensor
Old Oct 20, 2009 | 10:46 PM
vpatrol's Avatar
Default brake pedal sensor
Is the brake pedal sensor interchangeable between years? My 94 needs a new one and I can get one from a 93. The part number is different unless the guy has the wrong sensor identified. He's parting one out online. Is it worthwhile to just get a new one since it sounds like the go often enough?
Old Oct 21, 2009 | 09:18 AM
fcpgroton's Avatar
Former Sponsor
I know the 94 and 95 850s have the sames sensor. I am pretty sure the 93 850 has the same sensor but I am not 100% on this because the 93 850 was a whole different animal.
Old Oct 21, 2009 | 04:35 PM
arzy's Avatar
If you can solder they are an easy fix, pop apart solder pc board, silastic top, put together and you are done, saving $$$$
Take a look at this : https://volvoforums.com/forum/showth...highlight=arzy
Old Nov 18, 2009 | 11:21 PM
vpatrol's Avatar
pic of the sensor. The solder was required at the end of the circuit board. A quick job. Hardest bit was getting the casing open.
Old Nov 20, 2009 | 04:51 AM
D.Laply's Avatar
i just yanked out my all of my brake and clutch pedal stuff, its all garbage to me...
1996850turbo
Feb 12, 2014 12:14 AM
chef
Feb 16, 2009 08:27 PM
1996850turbo
Aug 26, 2008 08:35 AM
1999S80T6
Feb 15, 2008 05:50 PM
morningcalm
Dec 18, 2006 09:09 PM
