New 2000 V70
Old Oct 28, 2009 | 01:55 PM
MoneypitC70's Avatar
Default New 2000 V70
My fiance was in the market for a new (used) car and I happened to spot this 2 owner baby @ an auction. It was acquired for under $3k due to a few lights on the dash and other issues caused by a dying battery!! Thanks to this forum, I was able to dianose it immediately.
Old Oct 28, 2009 | 10:45 PM
checksix's Avatar
It's great to hear you are using the forums effectively and to take a looser and make it a winner for you. Please keep us up to date with your journey!
Jerry
Old Oct 31, 2009 | 02:58 PM
I did a cursory inspection before the purchase, so I at least knew the parts needed to make the car driveable: a battery, and it needed a full set of brakes/rotors. But after driving for a few days, the speedometer and odometer went blank, the abs light came on and the winter mode transmission arrow started to blink .... hello Mr. shorted ABS module.
So today I pulled the EBCM and shipped it off to the repair shop. Cost is $50 including shipping, lifetime warranty. Also completed brakes and rotors ($160 in parts) in 3 hrs with my fiance's help. Her favorite job was stepping on the brake pedal while i bled the system, lol. There was brakepad sized groove worn 1/16 deep into the front discs, no way were they ever turned.
While assembling the front brakes, i noticed the outer tie rods have a little play. Near future work: inner/outer tie rods, lower balljoints.
Happy Halloween!!
Smiling for the pic only, lol!!
Old Nov 1, 2009 | 06:54 PM
VTBricked's Avatar
I'm having the same symptom with my '98 AWD, but the code I get indicates incorrect gear ratio. How do you know yours is the ABS module? Did you pull the code? I have a parts car, so I can swap parts and an ABS module is a much easier swap than a transmission.
Old Nov 2, 2009 | 04:11 PM
The same exact thing happened to my C70....I pulled the abs sensor, sent it out to be repaired and then re-installed it. Absolutely 100% fixed the issues @ 10% of the cost.
Old Nov 9, 2009 | 09:22 PM
Reinstalled the ABS module tonight....the speedometer and odometer issue are fixed, but still have the blinking arrow. I will try to pull the code with my obdII scanner. Don't think it works on the transmission codes though. The car shifts fine so far.
Old Nov 9, 2009 | 10:28 PM
Somthngfrce's Avatar
Clear the code for the arrow and see if it comes back.... Might be due to the sensor. BTW, clean wagon!
Old Nov 10, 2009 | 09:39 PM
Will do, thanx!
Old Nov 15, 2009 | 10:52 AM
Cleared the eng/trans codes (my OBDII reads transmission codes) and the arrow went away.....but the check engine light came back on with an oxygen sensor code. Oh well, looks like a bit more wrenching is in order.
kraken
Apr 8, 2015 12:30 AM
Jtmdv
May 23, 2011 02:30 PM
lifelesslived17
Feb 19, 2010 09:28 AM
sk799
Oct 17, 2005 09:16 PM
