any tips/tricks on removing the rear driveshaft?
Old Nov 9, 2009 | 12:19 AM
bgeacook's Avatar
Default any tips/tricks on removing the rear driveshaft?
not a rear axle but the driveline. Say a prayer w/ me that its whats causing the shudder when turning. I plan on removing it but wondered if there were any tricks to it or tips on easiest way etc.
thanks
And BTW what exactly goes bad on them and can they be rebuilt/repaired?
Old Dec 7, 2009 | 05:14 PM
VTBricked's Avatar
Just to be sure - you're talking about the driveshaft from front to rear, correct?
Tips - make sure the allen head bolts are clear of dirt, use a correct size & unworn tool, and tap the hex into the socket to ensure it is fully seated in the bolt. Do not use impact of any kind, but smooth, in-line torque to loosen the bolt. In fact, a flex-head ratchet is best because you can flex the ratchet so the handle is in the same plane as the fastener heads.
Remember the center bearing housing is bolted to the same bracket that the exhaust is hung from. So there are two bolts to be removed here, too.
Be safe and use jackstands.
Old Dec 19, 2009 | 05:06 AM
petes99xc's Avatar
https://volvoforums.com/forum/volvo-xc70-17/mild-vibration-while-accellerating-if-turning-13273/
I got a remanufactured driveshaft from Colorado Drive Shaft for about $410. It has been in the car for two months and is working great. The driveshaft job is quite easy.
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
russellsv40
Jun 2, 2011 12:02 PM
NCdad
Nov 20, 2010 11:14 AM
MarksS60
Aug 26, 2010 04:48 PM
AAIIIC
Jan 23, 2010 02:53 AM
