Volvo 240 Performance Parts
Old Nov 19, 2009 | 04:07 PM
adrenlineskater's Avatar
Default Volvo 240 Performance Parts
Any References who Makes Them Besides IPD and mines is N/A
Old Nov 19, 2009 | 06:25 PM
Somthngfrce's Avatar
IPD is going to be the main one. Being an NA there's not much to get and gain power..especially being a heavy little car.
Old Nov 19, 2009 | 09:32 PM
hotcrowd's Avatar
Talking
Hi adrenlineskater,
I have found these sites/companies to be very helpful in addition to IPD and FCPgroton and other parts houses.
http://www.avalancheperformance.com/ Avalancheperformance.com
http://people.physics.anu.edu.au/~am...andling_V2.htm
http://www.cravingboost.com/ Cravingboost.com
http://www.r-sportinternational.com/index.php R-Sportinternational.com
http://www.volvomotorsports.com/catalog/ Volvomotorsports.com
Also, after several months searching Volvo 240 forums online, I have learned that the Normally Aspirated B230f engine in the 240 can be made to squeeze out as much as 20-40 hp increase and about 10-25 ft/lbs torque at the wheels extra, but requires as much money and work as adding a turbo to it.
You'll need to upgrade the engine internals, port intake and exhaust, valve jobs, cam, ECU chips, head gasket, fit new exhaust, install different injectors and fuel regulator, better ignition components, and upgrade the cooling system.
For anything else performance wise, these cars benefit greatly from suspension and brakes upgrades, exhaust, different wheels and tires, and the best seats you can find to fit.
Best of success to you,
Brandon in Franklin, TN
Old Nov 19, 2009 | 10:25 PM
TIPSP's Avatar
Got Boost?
these are desent companies. Also check out
BNE's site: http://www.kaplhenke.com/
Josh's site: http://www.yoshifab.com/store/
Ash's site: http://dvs.net.au/index2.html
Old Nov 20, 2009 | 06:24 AM
Cavingboost.com FTW!
Old Nov 20, 2009 | 07:09 AM
adub96's Avatar
If you really want to make power out of an NA motor and keep it NA you're going to need to get a ITB kit, you can make your own or buy one, engine management you can go cheap and use a megasquirt kit, crazy headwork, and a really hot cam. After that headers exhaust, a bunch of little things. And you'll end up spending like 1500 for all that. Or just go +t for like 500 and make more horsepower than you have seen from staying NA.
Old Nov 26, 2009 | 09:06 AM
Thanks Everybody
Wesley brown
Jan 4, 2015 08:56 PM
gccarter
1998-2000 model year V70
Sep 18, 2014 11:47 PM
volvosaabtech1983
Nov 19, 2012 08:54 PM
IPP
Oct 13, 2011 08:31 AM
xpiecemealx
Mar 17, 2010 09:10 PM
