How to remove flame trap
Old Feb 9, 2010 | 02:52 PM
Mk Ellis's Avatar
Default How to remove flame trap
Hello all. My Haynes manual doesnt show squat about the flame trap. From what I've been able to pick up on from these forums, is that it could be a cause of engine oil leaks. I have one leak from underneath which I thought could be the rear main seal, but now It's leaking from around the oil filler cap too. Anyone ever pulled the flame trap off? How hard? What needs to be cleaned or stops up on it? Many thanks in advance. By the way this is an 88 740 GLE non turbo.
Old Feb 9, 2010 | 07:37 PM
blue goose's Avatar
Take a look at the Brickboard FAQ.
http://www.brickboard.com/FAQ/700-90...ion_A_Treatise
Old Feb 9, 2010 | 08:20 PM
Beardog's Avatar
its easy enough, just need some thin hands and nimble fingers. I can do it and I have large hands. just go and replcae the oil filler cap and the valve seal afterward, or the cap grommet if you can buy one easily. they are probably both toast.
Old Feb 15, 2010 | 12:33 PM
sgtsteve007's Avatar
do you have to remove the intake manifold to complete the job?
Old Feb 15, 2010 | 04:37 PM
Titan Joe's Avatar
I've done it both ways. The first time I removed the intake. The second time I knew pretty well what I was doing and had the throttle body off as well. It took a bit of jerking things around to move it past wiring harnesses and other things down there.
Old Feb 15, 2010 | 08:36 PM
tedv's Avatar
If the car has an EGR valve (California models), I don't know if it's possible to do the separator without removing the intake manifold--I couldn't do it. But I think this set up is only on the 940's.
Old Feb 16, 2010 | 04:46 PM
Its a 1990 240. And just trying to see how much time it will take. What do u guys reccomend leave the manifold on or off. Thanks
Old Feb 16, 2010 | 11:48 PM
96850urbo's Avatar
Thumbs up
I have never done the job but I have had the head off on my 90 740 turbo wagon. If I were going to replace the PCV system I would remove the intake manifold. There is little room to work otherwise and I know that when I do a job for the first time I like to really be able to see what is going on. So, my vote is for remove. And if you did it that way you could do some other preventative work like replacing your vac lines.
boarders123
Jun 23, 2012 09:16 PM
netconcepts
Aug 25, 2005 09:28 PM
FRANCISCO
Jun 16, 2005 12:02 PM
wavewright
Apr 10, 2005 07:21 PM
djbaines
Dec 16, 2004 12:22 PM
