Heater core replacement- need to drain coolant?
Old Mar 6, 2010 | 02:03 PM
elav's Avatar
Default Heater core replacement- need to drain coolant?
I'm about to replace my heater core on a 2000 C70. Do I have to drain the coolant first or is there a way to avoid having to drain it?
Old Mar 7, 2010 | 10:31 AM
mkc70's Avatar
Some of the write ups you read show how you can minimize your coolant loss with out draining. I replaced both radiator hoses and the thermostat at the same time with the heater core so did the drain.
Old Mar 7, 2010 | 12:50 PM
elav's Avatar
A friend and I replaced heater cores yesterday. I have a 2000 C70 and he has a 2000 xcountry. Both heater cores were shot. The xcountry's was worse but both were bad. We drained the coolant from the radiator and while I guess you don't have to I wouldn't do it any other way. Make sure to put the heater core in a trash bag before removing it. We caught almost all of the coolant remaining in the core this way which was easily 3 cups worth. All and all an easy repair.
Old Mar 10, 2010 | 09:54 AM
ogradystavern's Avatar
If you use a pair of pinch-off pliers on both heater hoses and the bag idea you should have very minimal coolant loss
Old Mar 16, 2010 | 04:28 PM
elav's Avatar
I thought about that but there didn't seem to be a lot of room in the engine compartment where the hoses turn to rubber. Draining wasn't too bad and it was due.
Thanks!
ycartf
May 6, 2013 11:19 AM
Tumbler
Jul 14, 2012 02:16 PM
s80turbo
Apr 24, 2011 06:31 PM
RRTEC
Dec 29, 2009 07:58 PM
Wovolvorine
Aug 7, 2009 11:37 PM
