Best place for switched, constand power in S70?
Old Jan 11, 2006 | 11:05 AM
AaronD81's Avatar
Default Best place for switched, constand power in S70?
I'm installing my handsfree phone kit and I'd like to know the best place to splice for the swtiched and constant power source. I know there's lots of them, but I'd like the one least likely to cause problems (blowing fuses, and also ease of installation). I saw that there's an accessory plug provided by Volvo, but I don't think it has a constand source. Any opinions?
Old Jan 11, 2006 | 11:23 PM
Default RE: Best place for switched, constand power in S70?
The ones I have seen were run from the fuse panel outside to inside.
Old Jan 11, 2006 | 11:58 PM
AaronD81's Avatar
Haha, I should just email you instead of posting. In my last car I used an "Add a Fuse" in the power door locks because it was high amp and rarely used, what do you think?
Old Jan 12, 2006 | 12:12 AM
That might do it. Or try to tap into the Cigg. lighter.
Old Jan 12, 2006 | 12:29 AM
AaronD81's Avatar
I would but I use it a lot and I'm not sure if it's meant to be used for running 2 things at once. I'll start with the fuse box and see what's available. Thanks.
Old Jan 12, 2006 | 11:28 PM
AaronD81's Avatar
I tested the accessory plug today and pin 1 is constant, 2 is switched (I think the book calls it "X"), and pin number 9 is a ground. This is perfect for anyone adding a phone kit, or radar detector or whatever.
Old Dec 16, 2006 | 10:15 PM
hywel's Avatar
Where is the accessory plug? Does an S80 have one, by chance?
Thanks...
Old Dec 19, 2006 | 04:24 PM
cbevis's Avatar
accessory plug = cigg lighter if there isn't an actual lighter in the soccet. Keep in mind that the accessory plug is fused for 12 volts (20 amps) worth of accessories. a radar detector maybe pulls a volt? A phone charger...perhaps two volts? Most accessories have in line fuses in there power cords at some point. For a phone charger, it's usually in the plug on the other side of the LED light. Same for radar detectors. So a good way to check the draw on your soccet is to add up the amps represented on the respective fuses. If you're under 20 amps, you're golden.
of course, you should probably check to see what else is running off the cigg lighter/accessory soccet fuse. there might be a dome or door light tied in with it too...or something. At any rate...Walmart, Target or Radio Sack sells accessory expanssion kits that'll give you 3 or 4 more soccets...if you don't feel like ripping appart the cords.
Old Dec 20, 2006 | 12:28 AM
hywel's Avatar
OOOOOHHHH!!!!
You know, I was wondering about tapping directly into the back of the ciggy lighter socket. Sounds like a rational plan to me!
marvgt95
Dec 29, 2009 03:47 PM
bek
Jun 16, 2009 06:45 PM
MC92
Apr 19, 2009 09:11 AM
shimby
Aug 10, 2008 09:53 AM
CAMBRAJ
Nov 8, 2006 08:49 PM
