Many Random 850 Parts! (Long list....look and make offers!)
Old May 14, 2010 | 02:06 AM
moneypitbrick's Avatar
Default Many Random 850 Parts! (Long list....look and make offers!)
-BRAND NEW OEM 850 Tow hitch - pm me to discuss price and shipping
-BRAND NEW IN BOX front hub assembly - $75.00
-93-94 850 Taillight assemblies (Left and right) - $35.00 ea./$65.00 set
-T-5R/R door panels in charcoal (all 4 available) - make offer for one, set of 2/4 or all
-turbo fuel pressure regulator(low miles) - $55.00
-2 OEM grills - $50.00 ea
-850/S70/V70 headlight wiper (left/driver side) - $10.00
-OEM R and L side horns - $20.00 ea/$35.00 set
-Turbo/T-5R/R oem fog (left/driver side)- $50.00
-2 OEM MAFS (Mass air flow sensor) (0280217107)- $40.00
-TCU (transmission control unit) (from 1995 turbo/T-5R) - $35.00
-2 stock Turbo air intake box - $40.00
-3 EGR valve pressure sensors/solenoids (part #35311383) - $45.00 ea
-3 evap/canister purge valves (part #9135444)-fits 96-97 850's & 98-99 s/v70's - $25.00
-2 Evap charcoal canister - $25.00
-standard headlight lenses, R & L with gaskets - $20.00 ea
-sunroof (glass only) - $80.00
-NEW IN PACKAGING sedan trunk shocks (w/spoiler)- $30.00
-CBV for mitsu turbos(compressor bypass valve) - $25.00
-2 complete overhead light assemblies (both in tan)- $15.00 ea
-many oem gas caps - $7.00 ea
-2 battery clips (slide on battery tray to hold battery in place) - $8.00 ea
-Turn signals, several R & L - $20.00 ea
-2 Air guide/skid plates - $45.00 ea
-2 license plate brackets - $15.00 ea
- three pronged vacuum tree (near idle air control, under black cover; hooks up to the boost gauge line and the vacuum control solenoid under the radiator shroud)- $15.00
- idle air control valve: $30.00
- 2 sets: Two-piece stock air intake guide (connects to air filter box)- $25.00 ea.
- 2 93-95 airbag sensor - $50.00
- 93-95 ABS module (w/out TRACS) - $40.00
- Cruise control servo - $60.00
- 3 98-00 S70/V70 Vacuum valve solenoid/evap purge valve (sits under radiator shroud)- $30.00 ea.
- 2 TCV (turbo control valve)/BCS (Boost control solenoid) - $30.00 ea.
- ECT sensor(engine coolant temperature sensor) - $30.00
- Front windshield washer pump - $20.00
- Bosch Turbo "orange top" injectors - $50.00/set of 5
-SENSORS AND RELAYS COMING OUT OUR EARS. Too many to list. If there's one you need, chances are good we've got more than one of them. Please ask...
Old May 15, 2010 | 12:16 PM
Brand on the hub bearing(Front)?
Old May 17, 2010 | 02:41 AM
Dah_jOkA's Avatar
Do you happen to have both o2 sensors for a 1996 volvo 850 ?
Old May 18, 2010 | 03:38 AM
sure....SKF
Old May 18, 2010 | 03:39 AM
I don't, I'm sorry.
Old Jun 3, 2010 | 09:46 PM
Do you have the center taillight section from a 95?
Old Jun 7, 2010 | 12:17 AM
It's from a 96...I think they are the same...let me know if you're interested
Old Jun 16, 2010 | 07:46 AM
bshusted's Avatar
Does the driver's turn signal come with the black backing piece or is it just the housing? Also, you have headlight lenses listed, but do you have any of the reflectors? I need the passenger side.
Old Jun 23, 2010 | 07:56 PM
jacsil's Avatar
do you still have the trunk shocks?
Old Jul 5, 2010 | 04:33 PM
vans123's Avatar
complete overhead light assemblies (both in tan)- $15.00 ea are these still up?
Old Jul 5, 2010 | 05:23 PM
coyoteturtle's Avatar
I'm looking for the passenger side headlight assembly, including relays and wiring, for a 94 850 non turbo, would you have that? and the headlight glass for both headlights?
one to remember
Mar 13, 2015 12:50 AM
dwbf1
Jul 4, 2011 11:08 PM
moneypitbrick
Apr 13, 2010 11:25 AM
CarandAuto5
May 9, 2008 06:02 PM
