camshaft sensor and crankshaft sensor question
Old Jul 27, 2010 | 05:57 PM
the_brain3000's Avatar
Default camshaft sensor and crankshaft sensor question
hi,
even since i got the check engine light my 2002 Volvo s60 2.4T AWD i've noticed a pretty significant increase in fuel consumption.
the check engine light turned out to be a P0014(camshaft sensor) and P0016(crankshaft sensor).
what exactly do the camshaft sensor and crankshaft sensor do?
also, how hard is it to get to them and replace?
Old Aug 2, 2010 | 02:27 PM
T5-steve's Avatar
hi there,
these sensors are pretty common problems that occur with age.
yes they are easy to replace and cost around £50-100 for crank and cam (im obviously from the uk!!) so not much more in euros.
the sensors are used by the ECU to determine the position of the crank and cam for accurate engine running, and for emissions purposes. what symptoms are you getting as they sometimes show these are bad but its caused by something else ie p0014 means the exhaust cam is over advanced or system performance bank 1 so could a VVT issue???
hope this helps
steve
Old Aug 3, 2010 | 04:32 PM
Originally Posted by T5-steve
hi there,
hope this helps
steve
thanks for your input Steve!
i just got the car from the mechanic today after changing both sensors. costed me about 250€ with labor. the mechanic said the 2 work toghether and needed to be changed.
there were no obvious symptoms to be honest. one thing i noticed when trying to get more power from the car it would just dissapoint which it didn't usually do.
according to 2 mechanics i asked the risk was one day it would just not start or leave me stranded while driving.
now it seems lively and very responsive so it seems the problem is solved.
hopefully this will be the last i hear of it
thanks again!
Cristian
Old Aug 4, 2010 | 02:31 PM
T5-steve's Avatar
hi cristian, no problem as long as you think its sorted out
they can be awkward faults to diagonse and cure but your the only one who will if drives better so good news then!!
steve
mystiske
Jan 21, 2013 08:40 PM
joe maroon 850
Apr 2, 2011 02:04 PM
JHudson
Jun 21, 2010 04:04 PM
Jomo1994z71
Jan 4, 2009 10:37 AM
