sunroof rattle in the close position
Old Feb 4, 2006 | 05:39 PM
OME's Avatar
OME
Default sunroof rattle in the close position
My 02 C70 sunroof rattles in the closed position (end near the hood). The local volvo shop suggested replacing the sunroof seal. As anyone encountered this problem?
Old Feb 4, 2006 | 06:58 PM
cwworth's Avatar
Default RE: sunroof rattle in the close position
Is it the actual sunroof or the sunblind underneath? Is it particularly cold where you are?
The sunblind on my V40 rattles when the temperature drops below about 3deg C as the plastic hardens.
Old Feb 4, 2006 | 10:48 PM
reg's Avatar
reg
I believe they all do!! I took mine to the dealer for a 'warranty' repair and learned that after 90 days you are out of luck. If you wiggle it around it will stop squeaking.............or so I have found.
reg.
Old Feb 5, 2006 | 08:25 AM
mossop's Avatar
mine rattled it was a rather annoying tinny rattle.
all it was , was a metal strip at the rear of the roof had come loose one length of double sided tape and no more rattle and that was 6 months ago too!
so have look for anything loose before splashing out at a stealer
Old Feb 5, 2006 | 12:11 PM
OME's Avatar
OME
It's the glass portion of the sunroof. I've notice a little play in the rear of the sunroof in the closed position. The sunbinder is ok. There's no problem when the roof is in the tilted position.
Old Feb 5, 2006 | 02:00 PM
After_Shock's Avatar
Unfortunately with the way they are designed they simply rattle, its the plastic container which holds the glass thats the problem as it cant take the weight.
Old Feb 5, 2006 | 05:15 PM
OME's Avatar
OME
Can the plastic container be replaced?
Old Feb 5, 2006 | 08:27 PM
It can be but theirs no point as it will only continue to rattle after a short time with a new one in so for the cost of doing it its a pointless exercise.
Old Feb 11, 2006 | 04:04 PM
The screws are known to come loose for the glass. Try checking the screws first.
Old Feb 13, 2006 | 04:44 PM
reg's Avatar
reg
Yup..........you have to loc tite them!
p.s. Hey TECH.........I'm in Miami for a couple of days..............it's in the 50's down here. A couple of weeks ago I was in Ft. Myers (Sanibel) and we were in the high 70's!!!
R.
ORIGINAL: tech
Old Feb 13, 2006 | 09:23 PM
ORIGINAL: reg
R.
ORIGINAL: tech
It was in the low 50's here today all day. Going to be in the 20's tonight here.
Old Feb 14, 2006 | 12:13 AM
reg's Avatar
reg
Your oranges are going to freeze on the trees!!!! I'll bet tomorrow it will snow in Miami.......................
Reg
Old Feb 14, 2006 | 12:25 AM
We will see.
GOOD LUCK!!!
Old Sep 9, 2008 | 07:41 PM
bimmerd00d's Avatar
Bringing this back from the dead. I haven't looked at the car, as it's at school with my g/f. Her sunroof rattles, and i want to check these screws you speak of. Where are they?
Old Sep 9, 2008 | 08:01 PM
Tilt the roof into the up position. Then look closely at the plastic covers. I belive they need to be slid foward then pull them out.
Then you will see the screws.
Also look at the metal bars front and rear and make sure they didn't come loose.
Old Sep 9, 2008 | 08:02 PM
bimmerd00d's Avatar
ORIGINAL: tech
Awesome, will do. Love that quick reply
Old Sep 9, 2008 | 08:10 PM
No problem I just happened to be checking all new posts since last visit and it was there.
Sometimes it takes a few to get back.
When I get home from work I have to go through an average of 3 to 4 full pages a night.
Old Sep 14, 2008 | 06:15 PM
bimmerd00d's Avatar
ORIGINAL: tech
So I just took a quick look at the assembly. The front metal bar was just laying in there. I have pulled it out and put it in the trunk. I suppose we need to clean the dirt and gunk out and use some 2-sided tape to re-secure it. That sound like a good idea? Also, what do those bars actually do? I need to slide the plastic covers off to see if the screws are tight as well. Also, I think the drivers window regulator is going. When it's shut, and you attempt to roll it down there's a delay before the window starts to move. It seems like something moves, then the window snaps into action for the first few inches.
Old Sep 15, 2008 | 04:33 PM
Those bars are the glass support bars. Not sure if the double sided tape will hold it on.
Yes sounds like the regulator is going bad. That is one you won't ever want to do again after doing one.
Old Sep 16, 2008 | 01:08 PM
bimmerd00d's Avatar
Well, news on today. She went to close the sunroof today and somehow the interior shade is ahead of the glass itself, in turn not allowing the glass to fully close. how am i supposed to get the shade back behind the frontmost part of the glass so it can shut?
