AC fan
Old Aug 23, 2010 | 01:54 PM
skipowder's Avatar
Default Climate control problems
Hello, I have a 2006 XC70 and it seems that the climate control fan is stuck on high. I can turn the ac on and off, change the orientation of the blow, but I can't turn the fan down from high. Even when the key is removed from the ignition the climate fan continues to run for an undetermined amount of time.
Old Aug 24, 2010 | 10:39 PM
skipowder's Avatar
Really? Nobody knows what this may be????
Old Aug 24, 2010 | 10:46 PM
The climate module might have gone bad.
One thing you can try which might and might not work is disconnect the battery. Then tie the positive and negative cables together for like 5 minutes. Then reconnect the battery and see if that fixes it.
Old Aug 25, 2010 | 10:38 PM
skipowder's Avatar
Anybody think that the blower resistor might be the problem? I have heard that a couple of times. I have not tried the battery terminals solution yet.
Old Aug 28, 2010 | 08:32 PM
That is possible as well(resistor)
ingydrummer
Feb 28, 2020 03:33 PM
norasaint
Sep 20, 2012 12:53 AM
elouadj
Jun 25, 2008 07:00 PM
Nemesis
Oct 14, 2004 11:55 PM
chs68
Sep 17, 2004 03:13 PM
