A/C
Old Aug 30, 2010 | 08:23 PM
MyWifesV70's Avatar
Default A/C
My 2001 V70 A/C is not cooling on the passenger side. Drivers side is good, passenger side is low cooling.
Old Aug 31, 2010 | 02:49 PM
SVTfocusO3's Avatar
It may be a damper motor problem, but usually what I have seen is the system simply is low on freon, due to a leak. Check everything for leaks, especially the condenser.
Old Dec 28, 2010 | 08:43 PM
MyWifesV70's Avatar
Thank you. No need now that it is December @ 21F. You were correct, freon was low. So summer was not that bad.
