Missing vacum hose on a `86 240 GL
Old Nov 16, 2004 | 11:27 PM
flowerchild's Avatar
Default Missing vacum hose on a `86 240 GL
Hi all, we have a slight problem putting the engine and such back together after replacing several gaskets and seals that were leaking. There are 2 vacum hose attached to the part in the picture and we can only find one. I can't find any better pictures than this one of the hoses and was wondering if someone knew where this hose is supposed to be and if you could find me a good pic of it I would love that person forever!!!
[IMG]local://upfiles/1074/786F9E40B65B430DA0CB3DEEE97E6578.gif[/IMG]
Old Nov 16, 2004 | 11:53 PM
Default RE: Missing vacum hose on a `86 240 GL
I will look tomorrow and then let you know.Is it from the throttle body or the hose?
Old Nov 17, 2004 | 03:36 AM
There are 2 hoses coming off the round part in the center of the picture and I need to know about the bigger one, I know it goes there, but where does it come from??? If you could take a pic and post it for me I would love it so much!!! The car is almost together except for that darn hose and I'm pretty sure that's why it won't start...
[IMG]local://upfiles/1074/A3A03F1DCD2E4501AF5C9C45C2C661E1.jpg[/IMG]
Old Nov 17, 2004 | 10:40 PM
I didn't forge about you but we didn't have a 240 today.That will not make the car not run though.If you can give me a little more info about what you had apart.The hose you are talking about only has vaccum when the car is at mid to full throttle.
Old Nov 17, 2004 | 11:06 PM
We took off the bell housing and the removed the engine to replace the drive shaft seal.
Old Nov 17, 2004 | 11:25 PM
You replaced the seal in the back of the engine?If so and you didnt install the flywheel in the exact same spot that is why it isn't starting.There is a sensor that reads the outside of the flywheel to tell the car when to start.If you didn't mark it and put it back properly it will not start.
Old Nov 18, 2004 | 03:56 AM
yep, we reinstalled the flywheel properly. My fiance thinks it may be because we don't have any gas or that the cables for the fuel injectors are on the in the wrong order. All we really need now is to find out where that vacum hose is. I really appreciate you helping me out like this.
Old Nov 18, 2004 | 11:16 PM
I will try to find out for you.
roxpeppy02
1998-2000 model year V70
Aug 31, 2012 11:07 AM
gentlejax2
Mar 5, 2012 08:17 PM
phillip gotts
Sep 13, 2010 09:41 AM
thejman
Jan 7, 2008 01:14 PM
anusi
Jun 4, 2007 03:33 PM
