Fan in high speed
Old Jul 10, 2006 | 05:00 PM
Long's Avatar
Default Fan in high speed
Hi
I hope I could find some answers in this forum, so please help me.
I’m new to Volvo. I have bought a Volvo v40 1.8 from 2003 about 2 months ago. The car has almost rounded 100.000 kilometres. Everything works perfectly until the last few days. The fan to front of the car is running at incredible high speed when the A/C is on. You can hear and feel the vibration from the fan inside the car. So I checked the coolant in the expansion tank. The level of the coolant is in the middle of its range. The motor’s temperature is normal.
Could somebody tell me what it’s wrong with my car?
Old Jul 10, 2006 | 09:24 PM
Default RE: Fan in high speed
Possible bad coolant temp sensor/Thermostat.
Old Jul 11, 2006 | 02:01 AM
cstem's Avatar
The condensor fan on these models is obnoxiously loud. They do push more air than any OEM fan I have come in contact with. The vibration may be due to a missing piece of fanblade or a loose fan. Check the fan assy mounting points too.
Old Jul 11, 2006 | 05:19 AM
Long's Avatar
In this 2 months I've never heard or feelt the vibration from the fan inside the car.
But in the last few days it sounds like an aeroplane. I will call my dealer.
Thanks to you guys...
Old Jul 12, 2006 | 11:12 AM
Long's Avatar
Is that possible to turn down the fan speed?
Old Jul 12, 2006 | 08:41 PM
No it is not.
Old Jul 13, 2006 | 06:05 AM
Long's Avatar
So the fan has only 1 speed and it turns on and off.
The speed is not depend on the motor's temperatur?
Old Jul 14, 2006 | 09:07 PM
No the Fan has Different speeds. But it takes much input to decide which speed it runs at.
If the sensor See's it is getting hot it kicks it into high speed.
The Fan always runs when the A/C is on.
If the fan is always running on High when the car is on Most likely the Coolant temp sensor bad.
Old Jul 16, 2006 | 08:47 AM
Long's Avatar
thanks for your answers, tech.
Old Jul 16, 2006 | 06:52 PM
Long's Avatar
This threat is closed...
Old Jul 16, 2006 | 07:53 PM
You get something figured out for sure?
Old Jul 17, 2006 | 08:17 AM
Long's Avatar
A mechanic will check it out next week. I'll keep this threat updated.
[IMG]local://upfiles/6193/3A90BF82106D4638A815036F9B713268.jpg[/IMG]
Old Aug 25, 2006 | 11:38 AM
Long's Avatar
Hello
Finally I got my car fixed. The mechanic told me that the fan was defected.
I got a new fan replaced. Now I can drive my car without thinking that I'm flying an aeroplan
Thanks Tech...
mathieu_p
Jan 19, 2013 02:06 PM
itr
Nov 22, 2010 07:05 PM
sdc2000
Jun 29, 2009 04:52 AM
jdsmith
Dec 15, 2008 05:00 PM
parrym
Nov 7, 2004 11:30 AM
