roof rail question
Old Nov 30, 2004 | 06:03 PM
98v70's Avatar
Default roof rail question
will a set of roof rails from another v70 fit on mine if mine didn't orginally come with them, without drilling or anything? i just purchased a v70 and it dosent have rail and I need them..so i don't want to buy them if they won't fit..anyone know? Thanks.
Old Nov 30, 2004 | 09:32 PM
Default RE: roof rail question
They will fit with minor modifications.
Old Nov 30, 2004 | 10:05 PM
98v70's Avatar
ANYONE KNOW WHAT THE PROCEDURE ENTAILS? A BRIEF DESCRIPTION? PICS?
Old Dec 1, 2004 | 12:57 AM
No i dont have any pics.You remove the molding on the roof unscrew 6 screws from the roof.Cut the molding you removed into i think it is 3 peices.Reinstall the molding and then screw in the rails.Thats about it.
Old Mar 1, 2005 | 12:50 AM
Schock Therapy's Avatar
I made that enquiry at a local dealer just today. They told me it takes them about an hour to install them. The factory rails are rather expensive, so if you are going to spend that kind of money you might as well spring for the hour of shop time, and save yourself the hassle. It's not something you want to screw up on!
Old Mar 1, 2005 | 09:54 AM
Yes it is kind of a pain and is better left for someone that has done it before.
Old Mar 12, 2005 | 02:12 PM
JimKW's Avatar
No way, it's easy as heck to put them on if you get the ones for your model. The side rails are called Euro Rails and the crossbars are called crossbars. They are sold separately. I bought them both on the internet. The Euro Rails I got used and the crossbars were brand new. Everything cost me a total of around $250 and I put them on myself in about a half an hour. You just take the old molding off and replace it with the new rails and molding that you must get when you buy the rails. I'm not a mechanic, and I did this with no problem. I think they changed in 01 so make sure you get ones for your year. I don't remember the years that are the same, but I am pretty sure I was okay with 98-00 for a 98 V70.
Old Mar 12, 2005 | 02:25 PM
ORIGINAL: JimKW
Now when you buy them they don't give you the short peices of molding anymore.You have to cut down the old moldings after careful measuring.
Old Mar 12, 2005 | 09:06 PM
JimKW's Avatar
I bought my Side Rails (Euro Rails) used and the guy gave me everthing off the other car. So I had no cutting to do. I got them for less than new from a dealer, but not half price like you normally expect when buying used. It took me about 3 or 4 weeks to find them used.
Old Mar 12, 2005 | 09:09 PM
If it could be found that way it would only take about 30 min to install.If the moldings couldn't be gotton with it it will take longer.
hovonogila
May 16, 2019 02:28 AM
wagone1
Sep 7, 2010 11:12 PM
endneu913
Feb 4, 2009 08:57 PM
creamsoda
Jan 26, 2008 06:39 AM
98v70
Nov 30, 2004 09:28 PM
