2001 brake light on
Old Dec 13, 2004 | 11:26 AM
rfred's Avatar
Default 2001 brake light on
The brake light on the dashboard has recently been lighting up on 2 occasions. It stays on for a few minutes and then goes out. The manual says it might be low brake fluid, but the level is fine. I know that the pads need to be replaced, but does the brake light indicate that? Any other ideas?
Old Dec 13, 2004 | 12:08 PM
Default RE: 2001 brake light on
Most of the time when your brake pads get low the fluid level drops some. When it hits a certain level the brake light will come on letting you know the fluid level is low.If the level is around the low mark when you go around a corner or up or down a hill it will come on.
Old Dec 14, 2004 | 09:50 AM
cwworth's Avatar
It is also possible, if the 2001 model is the same as the 97 model, that a worn clutch can influence the light coming on as they share the same fluid reservior.
nealeas
Mar 24, 2018 09:59 AM
VolvoS40S60
Sep 21, 2016 05:04 PM
keesue
Jan 16, 2012 07:08 AM
todd60
Nov 9, 2008 06:48 AM
Vlxx
Mar 30, 2007 11:44 PM
