S60 2001 'Urgent Brake Service' light
Old Dec 24, 2011 | 02:06 PM
keesue's Avatar
Default S60 2001 'Urgent Brake Service' light
This message appears for a bit in the morning and goes away shortly after warm up. The brake fluid is up-to-snuff and there are no brake leaks. Car has 63K on it - owned since new. Brakes were done at Volvo about 20K ago. I'm guessing it is a connector issue at the brake reservoir and will clean it. Not sure though...
Anyone have any insight into this?? Can't seem to find anything about it.
Old Dec 28, 2011 | 08:45 AM
ibanez958's Avatar
that msg usually come up when u r having a ABS or traction control problems. first I would check if u still have crusie control cuz that's the first function that they disable if there is a permanent fault
Old Jan 16, 2012 | 12:32 AM
keesue's Avatar
Hey, thanks for the reply.
Old Jan 16, 2012 | 07:08 AM
ThorsHammer's Avatar
I totally agree with the cruise check, just to rule out this case.
I do, occasionally, get this msg along with anti-skid when I leave the car out of the garage overnight when the temperature drops too much. Especially when there's frost.
I had it checked (read) at Volvo and came up clean, they said that some sensor is affected by the icing conditions thus triggering the message. And, of course, everything gets back to normal after warming up ;-)
Hope this helps.
kzs983
Jul 3, 2019 09:58 AM
Brittanie
Apr 3, 2019 08:36 AM
CASS60
Apr 3, 2019 08:29 AM
robingichuhi
Feb 22, 2017 04:34 PM
klodge
Dec 15, 2008 02:49 PM
