starting problems
Old Dec 28, 2004 | 05:12 PM
bccb037's Avatar
Default starting problems
I have a 89, 760 turbo, I live in toronto, my problem is, when the weather gets very cold, anything below -30 degrees my car does not start anymore, otherwise the car runs perfectly, some mechanics tell me is the timing belt, fuel pump, no spark, the motor is floated, the ignition coil, the starter, no gas. the distributor cap, I have ruled out l all these issues, I have spark, I have gas, the distributor is clean, no condensation, I have changed the spark plugs, changed the oil, spark plug cables are a year old. I am frustated, I do not what else to do. any fresh ideas are appreciated.
Thank you
Byron
Old Dec 29, 2004 | 02:47 AM
Default RE: starting problems
How old is the engine speed sensor?
Old Dec 29, 2004 | 04:08 PM
bccb037's Avatar
I believe the speed sensor is as old as the car, from 89,
Old Dec 29, 2004 | 04:42 PM
The sensor goes into the top of the trnasmission check the wire for the sensor if there is any cracks in the outside sheilding then replace the sensor.
ReneVersteeg
Apr 4, 2005 08:58 PM
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
rl92821
Feb 1, 2004 12:54 PM
