volvo idling
Old Jan 23, 2005 | 09:25 AM
awjonessr's Avatar
Default volvo idling
I have notice that when I come to a stop in my volvo 2000 s70 se the rpm's drop below 1000 then comes back up to right under 1000 rpm's (normal rpm)[sm=helpout.gif]. Is that normal or is there a problem brewing? I also sometimes feel some pulsating in my pedal when braking. I had the front brakes replaced about 6 months ago at the dealer. Do I need to have the discs turned??
Old Jan 23, 2005 | 12:44 PM
Default RE: volvo idling
For the idle problem you can try cleaning the throttle body.The throttle body's are very picky on the 99 and up cars because they are electronicly controlled.Then for the brakes the rotors are most likely warped but if they are Volvo rotors do not have them cut!!!! Volvo rotors can not me cut they have a special cut on them from the factory.If you cut them the will make funny squeeking noises and warp twice as fast.
Old Jan 23, 2005 | 03:37 PM
awjonessr's Avatar
Thanks...by the way where is the throttle body located on the 2000 s70 se model?[:-]
Old Jan 23, 2005 | 04:01 PM
If it is non turbo follow the hose from the air filter assy to the motor that is the throttle body.If it is turbo the throttle is under the intake manifold.
Old Jan 23, 2005 | 05:25 PM
awjonessr's Avatar
Thanks, I will look at it this week and let you know how it turns out
Old Jan 23, 2005 | 06:22 PM
That sounds good.
Old Jan 24, 2005 | 02:19 PM
awjonessr's Avatar
Ok I have the throttle body off (hose) and there is nothing in it. Is there something else I can check or do I need to clean the inside of the hose with something?
Old Jan 24, 2005 | 03:29 PM
The throttle body is a big rectangle aliminum peice that screws to the intake with 4 10mm screws.You should use carb cleaner to clean the throttle body.
Old Jan 24, 2005 | 05:15 PM
awjonessr's Avatar
Thanks, by the way can I just spray the cleaner into the throttle body and run the engine for a few minutes or is it necessary to take the entire throttle body off? Also in regards to the pulsating in my pedal when I brake the front brakes and rotors replaced on 5/26/04 by the dealorship. Do I need to have the discs turned or replaced?
Old Jan 25, 2005 | 12:22 AM
I would recomend removing the throttle body to clean it.But you will have to buy a new gasket.As far as the brakes if you feel the pulsating in the brake pedal it is the rear that are warped.If you feel it in the steering wheel it is the front that are warped.I don't reccomend turning the rotors you will have more problems if you have them turned.I reccomend replacing them.
Old Jan 26, 2005 | 12:10 PM
awjonessr's Avatar
Hey I just sprayed into the opening of the throttle body real good and it took care of the problem...thanks. I am getting ready to do a tuneup soon and was wondering where the firetrap (I believe that's the name) is...I was told that I need to check that along with changing plugs, air filter, fuel filter (where is the fuel filter?) oil, and oil filter. Is there anything else that should be checked?? I appreciate all your help...thanks
Old Jan 26, 2005 | 02:03 PM
On your car the flame trap is not serviceable.You can check the vaccum elbows good and make sure there is none that are clogged.The fuel filter is on the passenger side by the R/R tire under the car.I would also reccomend replacing the coolant if it hasn't been replaced within the last 30,000 miles.Other than that just check your brakes and make sure the pads are ok.
Old Jan 27, 2005 | 05:21 PM
awjonessr's Avatar
Where is the flame trap and the vaccum elbows ?
Old Jan 27, 2005 | 05:38 PM
There is a vent box on the front of the engine under the intake.It is a black box about 10 inches tall by about 8 inches wide.Not 100% sure about exact mesurments.Find the box and follow lines and check at elbows and connections.
wgsa13
Nov 22, 2019 01:19 AM
MSLamb5
Nov 17, 2013 12:32 PM
Joewill2848
Jul 6, 2011 06:17 PM
v0lv085o
Sep 9, 2010 06:23 PM
hendricksl
Feb 21, 2009 12:13 AM
