1991 240 Overheating
Old 12-16-2014, 09:09 AM
Monopod's Avatar
Default 1991 240 Overheating
Hey all, my '91 240 overheats at idle consistently. It does it both when the A/C is on and off. I replaced engine thermostat and flushed the coolant system replacing it with 50/50 mix. The temp. needle on the dash does not fluctuate wildly. While I'm moving it stays just a hair below the middle, but when I idle for more than about 5-7 minutes it shoots up pretty quickly.
Anyone have some suggestions on where to start?
Thanks!
Old 12-25-2014, 11:44 AM
I would check the actual temp with an ir sensor. Also, does the fan work?
Old 12-25-2014, 02:12 PM
is the fan working? the viscous clutch might be dead.... this guy says a ton of 91's have needed replacing....
http://forums.turbobricks.com/showpo...50&postcount=7
and this guy has details on testing it.
http://forums.turbobricks.com/showpo...50&postcount=8
kcash
09-08-2010 09:29 AM
Philly240
05-25-2009 08:52 PM
MUD
11-09-2007 06:52 AM
kvh
03-04-2007 07:43 PM
Al
06-30-2005 02:29 PM
Quick Reply: 1991 240 Overheating
