91 740 ECU Location????
Old 03-06-2006, 11:27 PM
CargutsInc's Avatar
Default 91 740 ECU Location????
I have a 91 740 and am trying to locate the ECU. I found one computer in the passenger side kick panel manufactured by Bendix which I am told is the ignition control computer. I was also told the ECU is on the right side of the dash, but have had no luck in finding. I have removed the entire glovebox and don't see anything.Also was wondering how to determine if my car is equipped with EGR or not. Any help would be greatly appreciated. Thanks
Old 03-07-2006, 12:56 AM
Default RE: 91 740 ECU Location????
Do you have a Square coil?
If not then that is the ECM. If you do then I think it is under the Drivers side.
To tell if you have EGR see if you have a Metal pipe that comes off the Exhaust Manifold and goes over to the intake area.
VolvoBug
10-13-2014 02:44 PM
makaveli2k
08-08-2012 12:32 PM
matt01
07-23-2012 11:12 AM
91shelby
06-20-2011 06:56 PM
bigern45
08-05-2008 08:14 AM
Quick Reply: 91 740 ECU Location????
