aight, car still won;t start...
after much work and parts replacement, i have come to the conclusion that my 1993 940turbo does NOT have a spark/electric problem. so what's next on the list? fuel... how would one go about trying to see if there is a fuel/lack of problem?!?!? anyone?!?!?! please???
RE: aight, car still won;t start...
Have you tried loosening the fuel line at the fuel rail?Or you can unscrew the fuel rail and carefully remove it keep the wires grounded try turning over and see if fuel comes out of the injectors.I would try to unscrew the fuel line and check for fuel first.You will need a 14mm and 17mm wrench.
How wet are the spark plugs getting?You might want to pull the fuel pump fuse remove the plugs crank the engine and make sure there isn't a lot of gas in the cylinders.Also unplug your coil wire so that you dont catch the car on fire.Clean the plugs good and reinstall and try again.If you can unscrew the injector rail and make sure none of the injectors are stuck open.If they are stuck open you will see it dripping.
