Headlights cause engine to overheat !
Old 05-31-2007, 07:23 AM
yzfoot's Avatar
Default Headlights cause engine to overheat !
Well not really but when I turn the headlights on the temp guage goes up to near the limit in about 30 seconds. When I turn them off the temp drops to normal. Maybe unrelated but recently I swapped in a different radio (plug compatable). Any ideas appreciated.
Old 05-31-2007, 10:36 AM
TedH's Avatar
Default RE: Headlights cause engine to overheat !
my guess is when you turn the headlights on there is a short in the dash pannel which is making your temp guage go up, you could take your instriment cluster out and chek for shorts and a faulty grid.
Old 05-31-2007, 01:08 PM
yzfoot's Avatar
Sounds like a reasonable next step. I haven't had the instrument cluster out before. Any hints on how to take it apart far enough to look at it ?
Old 05-31-2007, 06:09 PM
Old 05-31-2007, 06:54 PM
yzfoot's Avatar
84_240_dl_sedan please repeat your reply, I didn't get it..
I poped out the instrument cluster (2 screws port & 2 screws stb after you pop out the plastic insets left & right) short of an electical failure I don't see much that can go wrong other than a bad connection. Anyone seen the failure relating headights to the temp indicator ?
Old 05-31-2007, 09:27 PM
It must be a short somewhere because there is no way that it is actually causing the engine to run hotter. Try finding a new instrument cluster at the junkyard mabye.Or just deal with the temp gauge working a little weird its no big deal cuz the engine is fine.
abigweasel
04-05-2011 09:20 AM
VDriver24093
02-21-2011 04:35 PM
colt1911
07-12-2010 10:25 AM
96850urbo
12-30-2009 06:43 PM
jsmoline
11-30-2009 07:33 PM
Quick Reply: Headlights cause engine to overheat !
