How to get the air out of the cooling system?
Old 08-29-2006, 11:53 PM
madhatter's Avatar
Default How to get the air out of the cooling system?
The top plastic hose connection on my 91 940T radiator broke off (nice design guys) and I replaced the radiator with an updated metal one. It now occilates between half and 7/8 on the temp guage and I am guessing that there is an air pocket in the system somewhere but can't seem to get it out...is there a trick to getting all the air out of the system? Thanks in advance.
Old 08-30-2006, 12:20 AM
Default RE: How to get the air out of the cooling system?
It usually all gets out once the thermostat opens.
Are you sure the thermostat is good?
Old 08-30-2006, 08:27 AM
madhatter's Avatar
Well, I'm going to change it now I guess as it should be running a little cooler than it is, but it had been ok. Thanks.
Old 09-01-2006, 01:15 AM
I would partially remove the T-stat to let the air out,
clarkr
04-22-2015 06:25 PM
82dizzler
12-30-2010 09:55 PM
Eli Delta
05-06-2009 06:22 PM
volvoslim1
07-20-2005 08:12 PM
Quick Reply: How to get the air out of the cooling system?
