Other coolant/antifreeze options?
Old 04-29-2011, 01:19 PM
mandobizar's Avatar
Default Other coolant/antifreeze options?
Im ready to flush my coolant system! My nearest Volvo dealer(1 hour away) sells the coolant for $25 per gallon. My local auto parts sells Prestone 50/50 for $10-13. Would Prestone hurt the cooling system in the long run? IF NOT, Is the prestone for flushing any good? Do I use Di water for flush only and only 50/50 mix for refilling coolant? Im a newbie around here sorry.
1988 Volvo 240DL Wagon A/T w/ overdrive
Old 04-29-2011, 01:37 PM
brianb's Avatar
I've used the Prestone 50/50 on both my Volvos and have had no issues. When I flushed, I just ran distilled water thru it a couple times.
Old 04-29-2011, 01:51 PM
mandobizar's Avatar
Default Thanks brian b
THANKS! Prestone it is.
Old 04-29-2011, 05:15 PM
swiftjustice44's Avatar
Just be positive you use the standard type of coolant, generally greenish. DO NOT USE DEXCOOL varieties made for newer cars. I call it DeathCool...will cause issues. There's nothing special about Volvo coolant.
Sanel30
10-11-2013 02:53 PM
Parris CHello Robinson
09-12-2013 05:47 PM
x-angel
01-12-2013 08:34 PM
anjp
01-21-2012 09:23 AM
ledzep526
05-01-2008 08:32 AM
Quick Reply: Other coolant/antifreeze options?
