Filled Coolant with Gasline Antifreeze
Old Apr 4, 2007 | 11:25 PM
ledzep526's Avatar
Default Filled Coolant with Gasline Antifreeze
My son's "Coolant Low Stop Engine" message came on, and he mistakenly poured in a small amount of gasline antifreeze and water, and thankfully made it home. When I opened the hood, the cap was not on, which could have been a result of his carelessness or something more serious, and the fluid in the tank was green. Are there any suggestions on how I should proceed? Thanks.
Old Apr 5, 2007 | 01:42 PM
billofdurham's Avatar
Default RE: Filled Coolant with Gasline Antifreeze
I can't see that much harm would be done by adding what is, in effect, an anti-freeze. Having said that, itshould be removed as soon as possible.
Drain the system, flush out thoroughly with clean water and refill with a suitable mix of anti-freeze and water.
As an afterthought, make your son replace the cap to make sure he knows how it is done.
Old Apr 5, 2007 | 08:01 PM
Fisher's Avatar
Agree. I would drain the coolant and refill with distilled water. Keep filling and draining until it runs clear. Once it is clear, then refill with coolant and distilled water 50% mix. I would use either the Volvo coolant or Zerex brand G-05 coolant, which is similar.
Old Apr 30, 2008 | 10:26 AM
slegare's Avatar
Are these the only two antifreeze's that are appropriate? I got the same message and I'm wondering what kind to use....
Thanks,
Steve
Old May 1, 2008 | 08:32 AM
flanimal's Avatar
Gasoline antifreeze is largely isopropyl alcohol. If he only put a small bottle in there then I wouldn't worry, but too much might make a hot cooling system into a bomb.
Parris CHello Robinson
Sep 12, 2013 05:47 PM
jbellx3
Feb 13, 2013 02:12 PM
ChrisHuntze
Jul 7, 2012 01:52 AM
spankey
Apr 22, 2009 08:48 PM
S70driver
Apr 2, 2008 05:40 PM
