960 check engine light reset
Old 12-06-2005, 03:25 AM
128auto's Avatar
Default 960 check engine light reset
Hi all! I am new to this forum, just want to say hello to everyone. My name is Alex, living in Vancouver BC Canada, I have been working in the automotive for 15 years. Long story short, I ran into a problem here. I worked on a 93' 960 last week end, the arrow light flashes on the dash, I have scanned the OBD1 self test and found the problem to be the gear selector switch. Replaced the switch, reset the transmission code according to my mitchell on demand manual, the light went off. After I roadtest the vehicle, the check engine light came on, then I turned off the engine and restarted it, now the SRS light stays solid. I also notice that none of the lights are on when I turn the key to ignition position. I try to reset the light following the instruction http://www.brickboard.com/FAQ/700-90...neOBDCodes.htm but no luck. Any idea? Thanks in advance!
Old 12-06-2005, 08:39 PM
Default RE: 960 check engine light reset
http://www.troublecodes.net/Volvo/
See if this helps anymore. I always hold the button down like 8 seconds.
Also if it doesn't clear it might be a permanant fault.
It always take me 2 to 3 times to get the codes to clear.
Old 12-06-2005, 11:58 PM
128auto's Avatar
Thanks for the quick reply. I spent a bit more time on the car today and it turned out to be the alternator, when the SRS and check engine light came on, I measure the charging system and it was 11.7 Volts, not charging at all. After work I started the car up, all the lights went normal and I check the charging system again, it was puttting out 14.7 Volts. It doesn't do it all the time but I can reproduce, should I expect a faulty alternator? Thanks again!
Old 12-07-2005, 09:51 AM
I would suspect the Alt.
Old 08-01-2009, 11:46 PM
hernando2170's Avatar
battery
Old 09-18-2013, 08:32 PM
kg4ibj's Avatar
How do I reset the CEL on a 97 S90? The original code was PO103 so I replaced the MAF but the light remains on. I do not have a code reader so I am hoping I can reset with a paper clip or something similar.
Old 09-21-2013, 07:43 AM
Henry10's Avatar
You can go to Autozone to reset the ECU for free. Or you can build your own Code Reader -- see instructions on the Sticky.
Old 04-06-2014, 10:52 AM
RGHamilton57's Avatar
how to build code reader
ph0493
08-26-2021 06:12 PM
Lszul
04-27-2008 06:26 PM
fishballs15
06-07-2007 06:33 PM
GJVolvo
02-11-2006 05:59 PM
rp850
07-13-2005 10:50 PM
Quick Reply: 960 check engine light reset
