Dashboard Instruments
Old Jun 7, 2009 | 03:03 AM
nicholas787's Avatar
Exclamation Dashboard Instruments
Hi there,
I'm new to the forum, so Hello
I have a 1996 volvo 850 AWD.
Yesterday when i turned it on none of the dashboard instruments worked.
They haven't played up before, I've just had a few electrical faults with the cruise control and ABS.
I've searched this issue and there is a precious post about it, although the fault was never resolved..
Any Advice..?
Cheers
Old Jun 7, 2009 | 07:29 AM
Check all wiring from the battery out to all connections under the hood.
Old Jun 8, 2009 | 08:17 AM
Psaboic's Avatar
Fuses good?
Old Jun 8, 2009 | 05:53 PM
850tony's Avatar
grounding is my thought. might have a ground fualt.
Old Jun 9, 2009 | 10:32 PM
villagepc's Avatar
does the car run?
I had a problem like this with mine, the no dash light thing. In my case, it turned out to be the dimmer switch - bad.
If it's the same on your car, its the sliding (left to right) rheostat deal near the headlight switch..
I had a problem with the positive battery cable as well. It makes a nasty 90 degree bend that corrodes out over time... also under the fuse box where the main power line comes in...
Old Jun 19, 2009 | 02:39 AM
Default Done
FIXED
Thanks guys, i just took the dash apart a little bit and unplugged, the re-plugged everything, all systems go.
bye
Old Jun 19, 2009 | 09:57 AM
VJZ's Avatar
VJZ
Glad it worked out.
An AWD 850? Are you in the US?
Old Oct 5, 2009 | 01:03 AM
Default LATE reply
Sorry for the minor 4 month delay.
No, I'm in Australia...
2CMott
Feb 5, 2023 08:23 PM
edzjog
Apr 14, 2012 09:34 PM
macroes
Sep 12, 2010 07:22 PM
wolf
Oct 7, 2006 04:48 PM
comrusk7
Jul 7, 2005 12:11 AM
