Can someone run a test for me???
Old 08-02-2012, 05:28 PM
Default Can someone run a test for me???
I'm working on my '95 850 and need to know something. If you disconnect the right harnest from the top of the cluster, will the cruise control still work?
I need you to have the following to do the test:
1. 1995 850
2. VDO Cluster (the VDO cluster has the trip mile meter in the center and the total mileage on the bottom).
3. Working cruise control.
I'm starting to think that the cruise control gets it's signal from the cluster. I don't know any other way to be sure since my cruise stopped working after I worked on the cluster/harness.
Thanks and let me know if you have any questions.
Old 08-02-2012, 06:56 PM
Vmax's Avatar
I would I have a '97 with an XC70 cluster...
Old 08-02-2012, 07:02 PM
colt1911's Avatar
Smile Cruise Control and VDO
I'll try to trace it down on my Vida software, I jusst have to install my EWD to the pc, I'll try to get to it tonight and see what I can find for you.
Pete
Old 08-02-2012, 10:40 PM
I'm thinking someone with a '94 or '95 can lift the edge of their dash and unplug their cluster and let me know. This cluster / cruise problem is driving me nuts.
Old 08-04-2012, 03:41 PM
artbar92706's Avatar
Default Confirmed!
Hey RSPI,
As promissed, I did the test on my 96 850. I pulled out the connectors on my cluster and Booooing!!!! no Cruise Control. I pulled over reconnected the cluster and it was back.
You are right, it is annoying not having it, lol.
Anyway, I hope this helps narrow down your problem.
Art
Old 08-04-2012, 06:33 PM
LOL, Thanks a million. You are awsome. I was hoping that the '96 was the same as the '95. I pulled a harness from a '96 and it had 1 wire missing so I tried to fix the harness and may not have done a good job.
I'm pretty sure my cluster is bad so I'll go pull the one out of the '95 that just got dumpped there when they run a special/sale. They usually charge $35 for them and I'd much rather get it for $22 - $25 so I may go pull it and hide it. Heck, it's only $13 more dollars, I may just get it since it has the trip with it. Right now my temp gauge and my ambient temp sensor, along with my cruise signal is not working.
Again, thanks you have answered a good question for me.
Old 08-04-2012, 07:15 PM
Just went to Matt's site and found another response to my problem.
http://www.matthewsvolvosite.com/for...251862#p251862
It appears that the cluster gets a pulse signal from a speed sensor from the transaxle (where ever that is) and the cluster gets that signal and converts it from anolog to digital. So, either the cluster is bad, the wire harness job I did is bad, or the speed signal from the transaxle is bad.
I know I have a bad cluster so I'll change that first.
Old 08-04-2012, 08:48 PM
Brick850's Avatar
I have just pulled my dash pad off to fix my odometer, and did your test. The cruise didn't work either.
Mine is the 95 model with the speedo pulses from the transmission, from 96 onwards there was one less wire and the speedo got its signal from the ABS module.
Old 08-05-2012, 08:15 AM
Yw, glad I was able to help
Old 08-05-2012, 09:58 AM
gabyman97596's Avatar
I have a VDO cluster. If you want it let me know!
Old 08-05-2012, 12:27 PM
PM sent
yungprofit703
03-23-2011 08:52 PM
rspi
02-10-2010 01:52 PM
richsid
03-25-2008 01:01 PM
willko1
12-13-2005 01:38 AM
slotmachines
02-13-2005 01:54 PM
Quick Reply: Can someone run a test for me???
