can someone check their schematic for me
Old Feb 13, 2005 | 02:04 AM
slotmachines's Avatar
Default can someone check their schematic for me
I have a 94 940 that has a peculiar problem, when ignition key is in position 2 everything
works fine, when key is turned and car starts my power windows and headlights wont work.
The engine starts every time but when ignition key is at rest in pos. 3 (where it springs back
to after engine stars and key is released) no lights and no pwr. windows. I have replaced
the entire ignition key and switch assembly thinking that the problem had to be there but
no change. There has to be a common device that these units voltage is routed thru but I
don't have a schematic. If someone out there is good with schematics and could give
me a clue I would be very grateful, don't know where else to look.
thanks bob
Old Feb 13, 2005 | 01:54 PM
Default RE: can someone check their schematic for me
Have you tried to wiggle the key after it is running and does it come back on if you wiggle the key?
yungprofit703
Mar 23, 2011 08:52 PM
Cameronian
Nov 4, 2009 04:25 AM
Fifth
Oct 28, 2009 08:36 PM
detrock
Dec 30, 2007 10:30 AM
jjr_740
Aug 26, 2007 12:32 PM
