Car won't start, won't turn over
Old 11-10-2008, 10:27 AM
exotek's Avatar
Default Car won't start, won't turn over
So, i have some sort of issue with the battery being drained slowly. It takes about 6 days for the battery to fully drain, and its not the radio since i had it unplugged from the power. I try to boost it, the dash lights up fine, but the car won't even turn over. I do believe i hear something comming out of the fuel pump. The car started fine before the battery drained (a week ago). The car already has transmission problems (PMP switch) and potential fuel pump issues (once in a while it would take 10 minutes of cranking for it to start, but it would still crank). Any ideas on why the car wouldn't even turn over, not even a buzz out of the engine..?
Old 11-10-2008, 12:42 PM
Default RE: Car won't start, won't turn over
Maybe battery is so bad it cannot crank the motor over.
Sometimes the battery shorts internally and no matter how much juice you give it the short will now allw it to crank.
Old 11-11-2008, 09:32 AM
Psaboic's Avatar
+1 Seen thathappen several times
Gustav
11-11-2017 01:01 PM
mewtmath
10-14-2013 01:27 AM
summit
03-24-2013 02:10 PM
reggietre
04-16-2010 09:20 AM
reggietre
12-11-2008 10:20 PM
Quick Reply: Car won't start, won't turn over
