EGR delete? Yes?
EGR delete? Yes?
In Indiana we do not have emissions testing, and most of my friends have removed the EGR system on their cars.
I have a 96 T-5 wagon for reference.
How would the removal of the EGR system effect the car's performance? Has it been done successfully?
I would have to use a resistor to trick the EGR system into thinking all systems were go so I didn't get a CEL.
EGR is exhaust gas recirculation. It takes some exhaust gas from the exhaust manifold and draws it into the intake manifold, but only during certain conditions; typically at steady-state cruise situations. The EGR valve is just a high temp air valve that either allows exhaust gas into the intake manifold, or not. It is controlled by vacuum, which is controlled by a vacuum valve, which is controlled electronically.
So why is it there? It lowers NOx emissions by lowering combustion temperatures. But does it rob pwr? Most certainly; it dilutes the air/fuel mixture with hot HC laden gas.
The trick I've seen (haven't tried as yet) on other vehicles is to put a solid gasket (no hole in it) between the EGR valve and the intake manifold. The EGR will still open/operate normally, but it just won't allow the exhaust gas into the intake manifold. The beauty is it looks perfectly stock. Anyone tried this?
