steering wheel vibrations
Old Jan 28, 2012 | 11:09 AM
slimflex2's Avatar
Red face steering wheel vibrations
hey guys l need your help. my 850 shakes when l go above 70mph towards 80 and 90. wheel alignment was done a month ago.all wheel balanced.l just replaced the tires to see if it would stop and even replaced each with a spare tire but nothing has happened.what could be the problem.thanks.
Old Jan 28, 2012 | 12:16 PM
Man it could be a number of things. Do you feel it in the car or in the steering wheel? When I was driving my sedan I felt some vibrations that started around 78, went away at about 84, came back about 96 and away again around 105. Turned out to be the tires.
Most shops balance the tires at about 45 mph. I asked the shop to run the balance up higher to try to get it solved. I told them the speeds that I was having vibrations and they asked where I was driving that had those speed limits. LOL I think they ran it up some because I had no more vibrations below 85 mph. I did notice that my tires usually stayed balanced for about 3,000 miles. Also, if I ever spin tire and left any rubber anywhere they were no longer balanced.
The big thing about it is that if you have any suspension problems your alignment shop should catch it. Bent wheels and loose axles can cause vibrations as well.
How are all of your motor mounts?
Old Jan 28, 2012 | 07:19 PM
slimflex2's Avatar
lol.you r funny man.the car shakes and through the steering wheel.when it gets aabove 70mph it shakes. through the seats too like the tires are coming off.can a bad motor mount let the car shake too?l plan on replacing the upper mount with ipds mount.also my rim was bent a lil bit and l fixed it using a plastic mallet. And l got it balanced so l dont know why its still shaking.
Old Jan 28, 2012 | 07:52 PM
As explained, if they don't do a good job balancing or balance at 45 mph, it may shake at 75 mph. Good tires do make a difference. The faster you go the more sensative the car will be to bent wheels and other things like worn mounts.
Rotate the tires and see if it changes at all. If it does, maybe you need new tires.
This car is giving you fits. Have you gotten that ticking sound taken care of?
Old Jan 28, 2012 | 10:41 PM
It's also possible the brake rotors have a little warp to them. If you feel any vibration at all when stopping you'll also get a vibration at speed as the rotors hit the pads on the high spots.
Old Jan 28, 2012 | 11:25 PM
slimflex2's Avatar
l am 100% sure that the ticking sound is from the oil sump Orings. l see bubbles in the oil as explained on IPD website. and on Matts website they commented that l should change the rings and that will help cuz the lifters are being starved for oil. so l will change the rings and see what happens. this car has been giving me any big of a problem. you when u get a used car you will definately get something to fix. better off to get a new car.LOL
Old Jan 28, 2012 | 11:27 PM
slimflex2's Avatar
l dont have warped rotor.when l brake it brakes perfectly without any vibrations.thanks though for your input.l am trying to figure out what causes this vibrations.
trainlover
Mar 16, 2014 08:48 AM
nehopsa
Jun 24, 2008 11:20 AM
flamejet
Sep 10, 2006 02:29 AM
Jutboy244
Apr 26, 2006 12:49 AM
BlackDiamondBound
Aug 4, 2005 01:28 AM
