wheel bearing and bracket
Old 09-11-2014, 02:38 PM
snagbranch's Avatar
Default wheel bearing and bracket
Hello all.
I'm about to change my front wheel bearings on a 2009 C30. I've read that a new bracket was developed for the C30 of my year and should be replaced, because it can cause premature wear on the front wheel bearings.
My front right bearing is "toast" after only 110,000km!!
Does anyone have a procedure for changing the wheel bearing and hub and has anyone changed to the new bracket?
Thank you in advance for you advise.
Old 09-11-2014, 09:48 PM
ES6T's Avatar
The bracket is to hold the bearing in the spindle. Some would slowly work out and cause an ABS warning light.
240addict
09-14-2012 06:56 PM
curtorous
06-27-2012 07:37 AM
Tdog
03-09-2012 01:56 PM
98_V70_T5
08-13-2010 06:49 AM
dufzor
07-17-2009 08:11 PM
Quick Reply: wheel bearing and bracket
