1999 C70 Power Seat Problem
Old 07-11-2006, 10:32 AM
gasman59's Avatar
Default 1999 C70 Power Seat Problem
Hello there:
The driver's side seat on my 1999 C70 is dead. The passenger's is OK.
It has been acting funny for quite some time, running roughly when moving backward.
The other night while driving I detected a mild burning electronic smell and the next day discovered the seat was dead.
I checked and actually swapped the seat circuit breakers and no change.
It looks like the seat "Brains" are in a small black box under the seat and I have a few questions.
1. Is this the likely culprit?
2. Is the box swappable between seats?
3. How does one go about taking the seats out to do so. I removed the front mounting bolts and the seat swings up a bit, but not enough to access the rear cables connecting into the control box.
any help is REALLY appreciated!
Thanks,
Ron Y
Old 07-11-2006, 09:29 PM
Default RE: 1999 C70 Power Seat Problem
If it is slid back and covering the Rear bolts and deosn't work it will be a big pain.
Also check the Micro switch by the outside edge where the Seat pivots. The switches break out of the plastic and the Seat won't work.
Old 07-11-2006, 11:04 PM
gasman59's Avatar
Default Thanks for your help with the Power Seat Problem
Tech: Thank You, Thank You, Thank You!!!!!
The microswitch was indeed hanging loose. I can't figure out where it goes but I black taped it closed and the seat works. The "Auto Slide Forward/Back" when tilting the back does not work, but I really do not care about that.
Is there any other safety reason not to leave it taped closed as it is now?
Thanks ,
Ron Y
Old 07-11-2006, 11:07 PM
Default RE: Thanks for your help with the Power Seat Problem
That will be fine for now.
That switch only disables the Seat motors when the seat is folded foward for someone to get in the Rear.
Old 07-12-2006, 09:44 AM
gasman59's Avatar
Thanks again!
Boy I could see a shop charging a mint for this quick repair. Who would know?
"Removed the seat and changed the module".
Thanks,
Ron Y
Old 10-18-2015, 06:24 PM
corvairbob's Avatar
is there any photos of this location?
Old 10-19-2015, 06:24 AM
MSGTUSMC's Avatar
Originally Posted by gasman59
Thanks again!
Thanks,
Ron Y
Volvo charged me $1,000.00 to replace the 1st switch. It failed 9 months later, I replaced it the 2nd time, and used a heavier spring. I removed the seat and put it up on my bench.
securisign
05-31-2014 11:10 AM
Bobec
05-21-2014 11:35 AM
artisan
07-04-2011 12:42 PM
tr_car_nut
11-28-2010 08:10 PM
angelo08
09-10-2008 06:28 PM
Quick Reply: 1999 C70 Power Seat Problem
