A/C Service ports
Old 07-15-2008, 10:12 PM
2manycars1's Avatar
Default A/C Service ports
I have been trying to service my 2000 C70's A/C system, have been over (and under) practically the entire A/C line and have come to the conclusion that Volvo did not include a high pressure port. Is this true or am I just missing it?
Any help appreciated,
Thanks.
( I am also hoping the leak is ANYWHERE except the evaporator core!)
Old 07-16-2008, 01:29 PM
JimKW's Avatar
Default RE: A/C Service ports
As far as I know you are correct. The servicing is done through the low pressure port. It located next to the window washer fluid bottle kind of under the Power Steering. I'm fairly certain the 00 C70 is the same as the 98 V70 and the 850's.
Old 07-16-2008, 06:43 PM
You are both correct no High pressure port.
Old 07-16-2008, 10:03 PM
2manycars1's Avatar
Thank you both for your help!
Old 10-05-2012, 07:46 PM
MSGTUSMC's Avatar
Default A/C pressure ports 1998
1998 C70 high (liquid) pressure port is just to the right of the radiator. The low port (gas) is located on the a/c compressor just inside of the drivers front wheel. Serviced mine today!
xc60vivi
04-11-2015 07:54 AM
97black850
04-16-2013 07:41 PM
chef
01-22-2009 01:46 PM
kartman01
07-03-2008 09:16 PM
ckuttner
08-09-2007 08:26 AM
Quick Reply: A/C Service ports
