Cooling Fan C70 Not Turning On
Old 07-18-2009, 06:46 PM
markfrantz's Avatar
Default Cooling Fan C70 Not Turning On
Just replaced a cracked radiator in my 99 C70 and the cooling fan was working perfectly before the install, but is not turning on now. Tested the relay and fan, they are both good. Turned on AC and still nothing. Sender bad??? Any ideas???
Thanks,
Mark
Old 07-18-2009, 07:35 PM
The ect might be messed up but on the other hand there is 2 circuits for the cooling fan.
The A/C is a different circuit from the coolant temp sensor. Double check all connections.
Old 07-18-2009, 08:06 PM
markfrantz's Avatar
Default c70 fan issue
Is the ect the same as the ecm? and I tried all the connections onthe relay and the fan connections....what else could it be?
Old 07-18-2009, 08:50 PM
The ECT is the electronic coolant temp sensor located in the thermostat housing. Follow the upper hose to the motor. Then look under where the hose attaches there is a sensor that is the ECT.
But if that is bad then the A/C should still turn it on.
That's why I said to double check all connections. Make sure none of the wires backed out of the plugs.
02VolvoS40
08-26-2019 08:02 AM
rolandt
10-16-2017 12:24 PM
norasaint
09-20-2012 12:53 AM
SpaceCadetSD
03-12-2009 07:29 PM
elouadj
06-25-2008 07:00 PM
Quick Reply: Cooling Fan C70 Not Turning On
