SRS Light 2002 S40
Old 01-31-2012, 05:07 PM
Detrias's Avatar
Default SRS Light 2002 S40
I recently had to replace my driver side door window regulator assembly, it wasn't much trouble besides that after i was done now i have the SRS light turned on. I was wondering if perhaps theres something i might have overlooked and forgot to plug back in? Where is the airbag cable located for that matter, cause i only remember having to plug back in the regulator motor and the control unit, besides that i don't recall any other cables down there. Any help on this manner would be greatly appreciated
Old 01-31-2012, 10:04 PM
AutoNaut's Avatar
Old 02-01-2012, 04:43 PM
Hudini's Avatar
I too have the SRS light on in a 2001 S40. If I read VADIS correctly, I need to connect a DICE tool to read exactly which sensor is reporting the problem. It could be anything from a seat belt not connected to a bad airbag on mine.
Let us know what you find with yours.
Old 02-02-2012, 05:04 AM
Detrias's Avatar
Thanks for the diagram, I'm busy with class till friday but i should be able to work on it during the weekend. Il update the post once I'm done
Old 02-02-2012, 10:29 PM
AutoNaut's Avatar
Just to scare you all... My SRS light came on in my '02 S40 and I took it to the dealer. First they said it was a left side impact sensor. They replaced it and the next day the light came on again. I took it back and this time it was the left side air curtain. Now we are talking $$$$. Two days later the light came on again. I suggested that it could be a harness or controller issue. They checked the harness and ended up replacing the controller. The total bill was over $3000. Fortunately, I had the extended warranty.
My '04 Sienna SRS light came on and cost me $800 for a new controller.
My '05 V50 SRS light came on and it just took a software reload to fix.
I would check the connector that is under the passenger seat. They tend to get bumped by things rolling around the floor.
Stan
Old 11-24-2012, 05:16 PM
Johnny Hamm's Avatar
Sounds to me like the Volvo dealerships couldnt find their *** with both hands DUCT TAPED to their asses.
lister99
12-28-2012 10:46 PM
Danigirl
02-22-2012 01:36 PM
nyc1836
09-07-2011 08:33 PM
john5000
05-05-2010 11:08 AM
Sparky4688
09-26-2009 06:22 AM
Quick Reply: SRS Light 2002 S40
